Front springs to match SS+ rears
Daytona
Re: Front springs to match SS+ rears
Post by Daytona » Sat Jun 03, 2017 11:14 am
jonytek wrote:
Wed May 31, 2017 4:23 pm
I'm confused what it is you're after, sorry if I'm stupid. I have a set of SS+ springs at home that you can have for cheap if that's what you're after?
Did Audi release 3 different options for springs on the b7? I though it was only 2, SS & not and SS+ was the same as SS.
You're right, two options, Sports Suspension and Sports Suspension plus, the latter having stiffer springs, lower at the rear, (think the front is the same as SS) and thicker ARB, front, rear or both, can't remember.
In a nutshell:
I was just asking if there was an off the shelf spring option that lowers the front enough to match the rear
Daytona
Post by Daytona » Sat Jun 03, 2017 11:18 am
JCviggen wrote:
Thu Jun 01, 2017 11:19 am
marc1 wrote:
Wed May 31, 2017 7:56 pm
Why would you only change the fronts? The spring rates are usually different on aftermarket stuff, so aren't you just messing with the balance? Can't imagine handling is going to be optimised. Just replace all four like most people do.
I fitted H&R front springs and left the SS+ rear and the handling is perfect, Nurburgring included, it has hardly changed at all from stock maybe a tiny bit less understeer thanks to the lowering which gives a tad more negative camber.
I reckon spring rates are pretty close, and definitely not a concern.
Is your car a saloon, Avant or convertible, do you know if the fronts springs are the same part irrespective of body style?
jonytek
Post by jonytek » Sat Jun 03, 2017 1:31 pm
I'm impressed with how round the wheels are in the diagram.
BUILD THREAD
IG: @bad_rs_4
Daytona
Post by Daytona » Sat Jun 03, 2017 2:07 pm
2p's :thumbs:
kd
Post by kd » Sat Jun 10, 2017 9:54 pm
I agree thats some really good circles on the drawing
:thumbs:
Mine has SS+ on the rear and H&R on the front and it balances out perfectly with the factory DRC . I had the 4 wheel geometry done after install and have tested it on a track and general day to day driving without any problem at all. I will take a picture tomorrow. I had the same issue as you, I hated the way it sat with the SS+ which just looked so exaggerated on the avants. Mine are on the 20" S5 alloys. I had to buy a set of 4 H&R springs and donated the rears to someone on the forum that needed them.
kd
Post by kd » Sun Jun 11, 2017 1:07 pm
Brooner
Post by Brooner » Sun Jun 11, 2017 1:11 pm
I'm sure Glenn changed his suspension on his B7 to give a more level look on him I'm sure he'll sort it out for you
2018 B9 RS4 Navarra Blue
2013 B8 RS4 Sepang Blue
2007 B7 RS4 Avant Sprint Blue
2001 B5 RS4 Nogaro Blue
1993 B4 S2 Avant laser Red
Daytona
Post by Daytona » Tue Jun 13, 2017 9:57 pm
:thumbs:
Know what you mean with it being exaggerated on Avants plus I'll be eventually going down the 20" S5 wheel route too which would make the front look like it was on stilts!
kd
Post by kd » Tue Jun 13, 2017 10:06 pm
Not the greatest angle on my picture on the link above but it gives you a good idea how it sits with the SS+ on rear and H&R on the front. I had the same set up on the OEM 19" wheels and it sat perfectly as well. I really like the 20" S5 wheels as they really fill the arches well and with the unlucky incidents with the car being broken into a couple of times any aftermarket alloys I dont think will last long on the car so this is a great compromise for me...even though there are many I would jump at if I had more secure parking :-)
Daytona
Post by Daytona » Tue Jun 13, 2017 10:17 pm
Yea seems you can't have anything nice without some scr0te nicking it.
Have you got any other pictures as your link is asking for sign in details?
kd
Post by kd » Tue Jun 13, 2017 10:23 pm
Oh sorry try this one, if not I will have to find somewhere to upload it
https://1drv.ms/i/s!Ag_fcZQy7nDjiTj000b7S5nl0yXH
Daytona
Post by Daytona » Tue Jun 13, 2017 10:24 pm
Same thing mate
kd
Post by kd » Tue Jun 13, 2017 10:51 pm
Ok last attempt :-) If this doesnt work send me your email on PM and I will email you
https://www.flickr.com/photos/151729696 ... res/5cs7t4
Daytona
Post by Daytona » Tue Jun 13, 2017 10:54 pm
Can see it now, cheers, looks great, nice and level :thumbs:
irn_bru_ce
Post by irn_bru_ce » Tue Jun 27, 2017 2:31 pm
Contact http://www.dfaulknersprings.com/acatalog/Specials.html , they can wind any spring you want, Ive used them before and know loads of other that have ordered from them with no hassle
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 98 guests
