When I switch on my headlights, the drivers side is aiming at the floor. It then adjusts itself to its normal position (matching the n/s)for about 30 seconds, then goes to the floor again.
Any ideas?
Will vag com help?
Thanks in advance
Mike
headlights
- mikeyquattro
- Top Gear
headlights
Tomorrow is another day
RE: headlights
I think there are some basic settings and output tests that can be be performed but if you are only having 1 move about you may have a dodgy headlight to deal with rather than a problem with the self levelling actuators.
Be careful out there or your arse may be sorry.
tartan_rob
RE: headlights
It is an intermittent short in the self levelling wiring. I have the same problem. I have disconnected the headlight range motors as I could not trace the fault. I know that it is a legal requirement to have the self levelling system operational but I have my lights set low so as not to dazzle anyone. Not the best solution but will buy you some time.
2017 Kawasaki Z1000
2014 RS6
2014 S1
2014 RS6
2014 S1
