B5 S4: What every owner should know
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
Dippy
Post by Dippy » Tue Dec 19, 2006 3:07 pm
This thread is an index to other threads containing important information about the S4, and in particular the "known" issues. These are either design defects or weak point in the car which need to be fixed, worked-around, monitored and/or expected to fail at some time. Potential purchasers and new owners should spend some time reading these threads.
Adding posts to this thread
Members are welcome to add to this thread as long as the following rules are met:
1) This thread is not for discussion - if you want to ask about it please start a new post.
2) New issues should follow the same format - a clear title followed by a short concise summary, then links to the threads that provide the detail.
3) Existing issues can be edited, primarily to add more links. If you can't edit the thread, either add a post with the changes, and a moderator will tidy the thread later, or else start a new thread requesting the changes.
2001 Silver S4 Avant
Dippy
RE: New S4 owners - things you should know
Post by Dippy » Tue Dec 19, 2006 3:10 pm
BUYERS GUIDES
The following links are to threads which have advised potential new buyers about what to look for when looking at S4s to buy.
The differences between pre-facelift and facelift
http://www.rs246.com/index.php?name=PNp ... t=facelift
Dippy
Post by Dippy » Thu Dec 21, 2006 8:49 pm
WINDSCREEN WASHER BOTTLE
There are known failures here which affect the whole B5 range (yes, even Dippy's "last-off-the-production-line" S4 suffered a failed pump). Failures can include the bottle cracking and pipes coming loose, but the main problem is that the pump itself develops a catastrophic crack in the body or seals. For more information see the following links:
http://www.rs246.com/index.php?name=PNp ... mp;t=58150
QuantumJohn
Post by QuantumJohn » Wed Jan 03, 2007 7:09 pm
Water Ingress
In certain instances water can find it's way into the cabin and soak the carpets. If it's not the heater matrix(which is rare to fail) - the water will taste sweet becuase of the antifreeze in it, it is probably this problem:
http://www.rs246.com/index.php?name=PNp ... r+footwell
John
Dr-Al
EXHAUST MANIFOLD RATTLE
Post by Dr-Al » Wed Jan 24, 2007 11:37 pm
Early B5 S4s (pre-facelift) had a poorly designed exhaust manifold. These have a heat liner on the inside that can become detatched from the outer casing causing an annoying rattle.
The design of the manifolds has evolved over several stages to eliminate the problem. It would seem that cars produced after the second half of 1999 are unlikely to be affected.
Unfortunately the only way to replace them is to take the engine out. Budget on £1,500 to £2,000 to get these fixed if you are unfortunate to have the problem. When replacing them, make sure you have both sides done (even if only one side is rattling) and specify that the replacements should be of the new design with improved welds. Sorry, I don't have part numbers (anyone else?).
I have written up my experiences here (with pictures)
Wrecked on 9 Oct 2007: 1998 Cactus Green S4, 710N DVs, Boost gauge (in custom A-pillar/dash mounting pod), cruise control retro-fit, Parrot 3200 Colour Hands Free, RS246.com sticker
Golich
RE: EXHAUST MANIFOLD RATTLE
Post by Golich » Sat Feb 10, 2007 2:33 pm
Also refer to the RS4 (B5) Buyers guide in the B5 RS4 forum 'sticky'. The S4 and RS4 suffer most of the same issues.
http://www.rs246.com/index.php?name=PNp ... ic&t=47136
Dippy
Post by Dippy » Tue Oct 16, 2007 1:46 pm
MCB
Post by MCB » Wed Jan 23, 2008 2:36 pm
OIL QUESTIONS AND ANSWERS
All you need to know:
http://www.rs246.com/index.php?name=PNp ... ic&t=67488
S4B5 Avant
bistduverrukte
Re: RE: New S4 owners - things you should know
Post by bistduverrukte » Tue Jun 06, 2017 11:25 pm
Dippy wrote:BUYERS GUIDES
This link no longer works
Sent from my SAMSUNG-SM-N920A using Tapatalk
Surrey Sam
Re: B5 S4: What every owner should know
Post by Surrey Sam » Tue Jun 06, 2017 11:41 pm
You're 9 years too late.
FON .
bistduverrukte
Post by bistduverrukte » Wed Jun 07, 2017 10:14 am
Noooo!!
Surrey Sam
Post by Surrey Sam » Wed Jun 07, 2017 10:56 am
Noooo!!
Because I'm nice and know how to use the search function, here is what you're looking for:
viewtopic.php?f=27&t=62407&hilit=facelift
lbray8425
Post by lbray8425 » Wed Oct 20, 2021 10:23 pm
