water pump or turbo
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
1z
water pump or turbo
Post by 1z » Sun Oct 02, 2005 12:51 pm
looking like my water pumps on its way out 58k started the car up this morning and soon turned it off, can hear a metallic ting, ting, tinge ,noise sounds like an impeller catching im assuming its the water pump, and not a turbo as it was making the noise running on 1200rpm so i wouldn't expect the turbo impellers to spin at 1200rmp or am i wrong
can anyone recommend where to buy a cambelt kit, at the right price,
or do i have to buy the bits separately
is this all the bits that i would need to order tomorrow
timing belt
- Water pump with gasket
- Serpentine belt
- Idler roller
- Tensioner roller
- Thermostat with O-ring
can anyone lend me a cam locking tool, promise to send it back
cheers
BRETTCOLLINS
RE: water pump or turbo
Post by BRETTCOLLINS » Mon Oct 03, 2005 1:32 pm
speak www.vagparts.com they will have all the parts mate.
MING BLUE AUDI S4
Car is on Lock down
506.9 BHP @ 6.020 RPM
445.0 WHP @ 5.981 RPM
481.5 IBFT @ 4.976 RPM
philipwalker
Post by philipwalker » Mon Oct 03, 2005 3:55 pm
The bar for locking the cams is fairly cheap at £60.
It may help if you borrow a set of slider pins for the front of the car. Gets the front end out by a few inches in the "service position". Makes the job easy.
Water pumps are cheap as is the repair/cam belt kit from the dealer , it contains most you will need.
Top tip for resetting the belt tensioner. remove it place it in a vice, close it and lock it in with a pin etc. Refit, remove the pin when you have timed the engine.
http://www.pwmotorsport.com
PW Motorsport
01437 563929
gavsteryoung
Post by gavsteryoung » Mon Oct 03, 2005 3:56 pm
I'm pretty sure the turbos will be spinning even when the car is ticking over..... I would go as far to say that on tickover there probably spinning at more than 1000rpm....
If it were turbos it would be high pitched..... if you can here it clearly tinging as you call it and it get faster with revs I would look around the front of the engine.
Infact I would listen under the bonet turbos and waterpump are at opposite ends of the engine it should be clear where the sound is coming from.....
hope this helps...
09 Audi S3 - Sprint Blue
99 Audi S4 - Ming Blue - (Gone but not forgotten)
04 Vauxhall Tigra 1.8 Sport - Antiga Blue (The Mrs Car)
Dippy
Post by Dippy » Wed Oct 05, 2005 11:09 pm
2001 Silver S4 Avant
Users browsing this forum: No registered users and 83 guests
