Brake noise
2.2 I5 20v turbo - 315 bhp
alastairg
Post by alastairg » Mon Oct 03, 2005 9:43 am
I spent a long time trying to solve this type of problem. Remove the calipers, remove spring plates, clean up 'corrosion build up due to steel/aluminium interface',replace spring plates with new ones, dry fit pads and check free movement. Replace
My calipers that the dealer overhauled were removed to allow big red upgrade. When I cleaned them up after removal one of the spring plates was slightly distorted by build up that had not been fully removed, catching one of the pads.
The symptoms u describe mine and I would do this first.
RS2 'an estate car named Desire'
VaudiGR
Post by VaudiGR » Mon Oct 03, 2005 11:56 am
ok.will do!thanks
Return to “RS2 (B4) 1994-1995”
