Front LSD
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
SilverS4
Front LSD
Post by SilverS4 » Sun May 28, 2017 9:01 pm
I'm having trouble with a front LSD.
The rear one went in ok, a Gripper plate and clutch.
Works lovely.
The front, I planned on fitting a quaife. Purchased it, took took it all apart to find out the front diff has an oil pump drive gear fitted and the quaife wasn't designed to take it.
No hole for the stopper pin and the bearing seat machines the thickness of the gear to short.
After speaking to quaife they advised me to talk to TSR in Bridgwater. I ended up with my money back and no upgrade to the front diff.
I know that gripper will make me a front that will fit. But that's a plate and clutch and I was advised to use an ATB style up front.
Maybe the advice is wrong for a quattro.
Does anyone have any advice or knowledge on this.
The good tech in my local Audi said something about an electric unit to drive the pump instead of the diff driven mechanical setup. He said that from memory there is a location and 3 holes in there to fit it.
Then advised me to ask on here.
Re: Front LSD
Post by bam_bam » Sun May 28, 2017 9:12 pm
Going from open diffs to LSDs on a quattro is pretty serious, what are you using this for, what's the rest of the build like?
I think jockthelad has run an LSD up front on a B5. Ask him.
SilverS4
Re: Front LSD
Post by SilverS4 » Mon May 29, 2017 9:18 pm
It has the usual fmic, rs4 b7 F and rs4 b5 R brakes, Rs6 turbos, 850nm clutch,
Rs2 plugs, gripper lsd rear.
3" into dual 2.5" zorst with the narrow joiners cut out and welded.
Makes 762mn at 4500
Bilstein b16 kit
Re: Front LSD
Post by bam_bam » Tue May 30, 2017 10:42 am
Is it a track car?
Email these guys info@akmotorsport.net and ask about their front Torsen differential from Porsche, matched to fit 01E, these will go on with oil cooling or without. Last time I asked these cost about 500 notes so probably more now.
I think it's jockthedog not jockthelad on here that has one fitted.
Eddie555
Re: Front LSD
Post by Eddie555 » Tue May 30, 2017 10:45 am
Is it a track car?
Bam your reference to "dog" and "lad" in the same sentence worries me. :shock:
Current ride’s
Previous rides
Users browsing this forum: No registered users and 118 guests
