Hi gents
My first post I don't own a RS6 I currently own a RS3 8V could anybody confirm please if it is possible to make any changes with VCDS & VCP on a facelift RS6 C7 66 plate.
I am currently running the latest software VCP 8.2.1.0/ VCDS 17.1.3.0 HexV2 I tried to make changes on a RS6 C7 66.
Long coding & adaptations would not let me make any changes in any controller on VCDS using Hex V2.
in VCP there was no labels or information in any controllers
09 channel map needed a security Access login code which I did not know i tried (20113) with no success.
Is it possible to make any changes with this ECU.
I kept getting request out of range errors when trying to make any changes & ECU not supported with VCDS.
I pulled some into from the vehicle a pre scan with lots of errors & controller channel map of 5F & 17 if this is helpful to anybody.
I have contacted the developers of VCDS/VCP to my amazement can't answer my question if there is support & is it possible to make changes with this ECU.
I would be gratefully appreciated if anyone can help me out with my questions.
Thanks gents.
AUDI RS6 C7 66 facelift Is there support with this ECU
Re: AUDI RS6 C7 66 facelift Is there support with this ECU
I've applied some of these to my FL RS6
http://www.maxcarblog.com/audi-a6/diy-a ... ps-tricks/
61378 rings a bell for a security code, but others may confirm shortly.
With Hex2 cable
@Hdpetehdpete wrote: ↑Sat May 27, 2017 7:59 pmI've applied some of these to my FL RS6
Thank you for the reply what year is your vehicle?.
I was going to make some changes from the link provided
http://www.vwaudiforum.co.uk/forum/show ... CDS-Tricks
Users browsing this forum: No registered users and 58 guests
