RS4 EPS Light on / Intake manifold flap
Re: RS4 EPS Light on / Intake manifold flap
CC is 850, map is 650 which is 1500 then there is labor to remove the flaps from you manifold. Sounds right to me. Rw@@dy didn't have the map which is why his was cheaper.
If you want the cheapest option then I have a manifold that I have just taken off which you can have for cheap then just get them or any other reputable indie to swap it over. This would keep you on the road for around 300-350 I reckon.
Ok that makes sense, So really there would be no need to get the remap then? Wonder why MRC advised for it to be done then...
I had a map just not from unit20, mrc did it after
Right Ok......So basically best to do what MRC are saying or either replace my manifold with another if I can source one that is if I dont wish to go down the MRC route of remapping etc.
I am evaluating my options before I make any rash decisions.
Why not get yours stripped out and then remapped
Spare inlet manifold: viewtopic.php?f=64&t=124505
What is the cost of getting them stripped out and remapped? Obviously remap is £650
I will speak to my mechanics tomorrow and see if they recommend buying a 2nd hand inlet manifold As that can be a cheap option.
When unit20 did mine, they said it was getting harder to get the spare parts to rebuild the flaps.
I believe the most time consuming part is removing the manifold, once off there are a few guides on here about removing the flaps
Awesome Gti do the modified flaps for these and bring them in from the states circa £210. I think thats very reasonable but they wont get them till the 2nd week of June so may try and source a 2nd hand manifold that isnt worn out or either wait till 2nd week of June.
- Dantheman84
- 1st Gear
No I removed mine but left the sensor/motor in place just remove the flaps no need to get remapped then car still thinks flaps are there so no fault will be recordedblitz wrote: ↑Sat May 20, 2017 8:44 pmSo just remove the flap? Is there no remapping involved? and if I just do this will the EPC light stay on?
OEM intake manifold is £2200 so the MRC route is cheaper which includes carbon clean, remap and im not sure what the other thing was maybe a manifold?
Ideally id like to save as much as I can, but dont want to cut corners to cause future problems.
RS4 kw v3 full miltek no cats
Intake spacer deflap stage 2 flat shift launch
Kawasaki ZX10R 197bhp
What did you do in the end? Looks like i am having the same issue.
Current Toys -
B7 Audi RS4 Avant - Phantom Black
E92 DCT M3 LE500 - Imola Red
Navara NP300 Tekna
E36 BMW M3 Evo track Car - Cosmos Black
Navara NP300 Tekna
Users browsing this forum: adamfraser, rshales007 and 140 guests
