Porsche / Brembo Callipers: Part numbers request
2.7 V6 30v biturbo - 380 bhp
K2
Post by K2 » Fri Jun 17, 2005 2:48 pm
Does any one know the Brembo or Porsche part number for the front 6 pot calliper conversion? I would just like some reasurance prior to going ahead with getting some on order. The parts I am after I think are GT3 racing callipers.
So far I have tracked down the part numbers for the road going equivalent UK GT3 Porsche Callipers as
996 351 431 90 left side
996 351 432 90 right side
DavidT
RE: Porsche / Brembo Callipers: Part numbers request
Post by DavidT » Fri Jun 17, 2005 3:33 pm
You may have done this already, but I'd suggest calling or better still visiting a Porsche parts counter. I have found them to have excellent customer service, they will show you the options and prices.
K2
Re: RE: Porsche / Brembo Callipers: Part numbers request
Post by K2 » Fri Jun 17, 2005 4:02 pm
DavidT wrote:You may have done this already, but I'd suggest calling or better still visiting a Porsche parts counter. I have found them to have excellent customer service, they will show you the options and prices.
Thanks, but the 6 port motor sport caliper which probably will not be stocked at the dealer costs much less than road going part , (wierd but true,)
£270 for 6 port racing caliper, £350 for 6 port road caliper.
I just wondered if any one who has undertaken this conversion has the references.
DavidT
RE: Re: RE: Porsche / Brembo Callipers: Part numbers request
Post by DavidT » Fri Jun 17, 2005 4:26 pm
You missed my point. The dealer will still tell you the part numbers, regardless of whether you purchase from them.
kalsket
Post by kalsket » Fri Sep 30, 2005 8:09 am
K2, could you check your motor sport calipers for part numbers? I would be very interested to have those. At least if they do have seals around pistons like road versions.
>RS4<
Post by >RS4< » Fri Sep 30, 2005 12:37 pm
Why don't you use the RS6 calipers?
An opinion is like an asshole,everybody has got one.
kalsket
Post by kalsket » Fri Sep 30, 2005 12:43 pm
In other topic it was said that these motor sport calipers could be as cheap sa 200£ each.
Other point: I'm planning those in other cars than RS4.
K2
Post by K2 » Fri Sep 30, 2005 1:54 pm
kalsket wrote:K2, could you check your motor sport calipers for part numbers? I would be very interested to have those. At least if they do have seals around pistons like road versions.
kalsket: the numbers are the same as those poted above. The road and race callipers are the same thing, only if you buy callipers from a racing team, you will probably get them at a reduced price, as porsche seem to provide consumables to the race teams at reduced cost :D
Mine were obtained from Parr in west sussex:http://www.parr-uk.co.uk/motorsport/his ... story.html.
kalsket
Post by kalsket » Fri Sep 30, 2005 1:58 pm
Thanks for the info.
>RS4<
Post by >RS4< » Fri Sep 30, 2005 5:04 pm
Are these motorsport calipers also "plug and play"on the RS4 (like the RS6 calipers)?
K2
Post by K2 » Sun Oct 02, 2005 7:11 am
Not quite as simple, they need a small machined aluminium block to convert the pick-up points from the upright to the new caliper. Other than that, its just as easy. If your interested I can point you towards a supplier of the machined blocks.
>RS4<
Post by >RS4< » Sun Oct 02, 2005 10:24 am
Okay i get your point,but i ask myself why not simply use the RS6 calipers?
If i read the article correct, those are P+P....and 8 pots....and OEM.... and cheaper... :roll:
bakerdcb
Post by bakerdcb » Sun Oct 02, 2005 12:52 pm
Just because they are 8 pots doesn't necessarily make them a better brake. They use 2 pads instead of 1 and this arrangement has caused some uneven wear and even a few cases of catching fire! The cost of replacement pads, which they tend to get through pretty quickly, is also quite high. The Porsche/ Brembo 6 pots are probably just as effective and there is a huge choice of different pads through Pagid so you can tailor your braking requirements to suit you. I cuurently run 'black fast road' for everyday use and switch to 'yellows' (extremely fade resistant) for track days. The wear rate is even and, I feel, superior to anything I might have put inside Audi oem calipers and I'm confident the braking is at least equal to what RS6 calipers would have given me. Any cost difference is pretty neglible in the long run :thumbs:
>RS4<
Post by >RS4< » Sun Oct 02, 2005 2:29 pm
That's a good explanation... 8)
Still if it was my decision i would take the RS calipers simply because i never do trackdays.
So basically it's just for the brakes to be better than the standard RS4 brakes,but overkill is not necessary...
On the other hand i really can understand people using AP's or Porsche's brakes if your doing trackdays.
