Front brake discs and pads replacement
Just picked my car from its 22,000 mile service to be told i need to spend £1211 on supply & fit of a new set. Pads are 90% worn and discs are scored. Has anyone got suggestions for getting genuine oem parts elsewhere cheaper? I cant seem to find the discs anywhere. Am i going to have to bend over and take a stiff one from Mr Audi Dealer?
MY18 RS4 Carbon edition in Nardo
Re: Front brake discs and pads replacement
Try TPS (the parts specialist) all VAG parts. Discs should last a bit longer than this? I've found red or yellow stuff pads to be v.good
they dont have a listing on their website for the RS4
- RossDagley
- Top Gear
Discs for 450GBP.
http://www.ebay.co.uk/itm/Audi-RS3-RSQ3 ... 2498893927
Pads are circa 150gbp (remember you need two sets as 4 ads per caliper). If you get aftermarket sport pads expect to pay 350ish for pads. Simplest thing in the world to fit yourself. If you can take a wheel off, you can fit discs and pads essentially.
Save yourself several hundred
Previously:
Previously:
Current ride’s
Previous rides
Previous rides
I asked if those discs on ebay were correct for my car and the seller replied that If I use the correct spacers they should be fine.........doesnt sound like they are the correct ones for the car if you need to use spacers does It?
No part number seems to be for an RS Q3 only
Macan GTS
Boxster S
Previously
Audi RS4 B8
Audi S4 B8
Audi S4 B6
Nissan GTR,
Lotus Elise 111R,
Caterham,
Golf GTi Mk 1, Mk 2, Mk 3, Mk 4, VR6,
Various SAAB Turbos
Peugeot 205 GTi,
RS2000
Boxster S
Previously
Audi RS4 B8
Audi S4 B8
Audi S4 B6
Nissan GTR,
Lotus Elise 111R,
Caterham,
Various SAAB Turbos
Peugeot 205 GTi,
RS2000
- RossDagley
- Top Gear
Have you tried stoke audi for parts?
Previously:
Previously:
I would first caliper the disk thickness first as Audi tried it on with me saying the disk front and rear needed changing
I had just change to my summer tyres and calipered the disks and had more than half the thickness left before they reached minimum
the pads were replaced and then disks cleaned up
That was last year and checking again this year when changing over the wheels I still have just over 1mm before the disks are done
So I would check them fist before shelling out for disks and pad
2018 B9 RS4 Navarra Blue
2013 B8 RS4 Sepang Blue
2007 B7 RS4 Avant Sprint Blue
2001 B5 RS4 Nogaro Blue
1993 B4 S2 Avant laser Red
Thanks for the advice. Visually they have a slight lip on outside edge and some shallow scoring. I will let a local brakes specialist look at them with a view to skimming them.
Call them up, I've used them for partsTweaky wrote:they dont have a listing on their website for the RS4
I will be getting brembo discs think near £550ish...from epc with the codes ..and ds2500 pads
I purchased OEM Discs and pads from Crewe Audi (they have an ebay Shop) and paid £550 for the front discs (Cant remember what the pads were). If you are thinking getting them fitted by an Audi dealer be aware that they are refusing to fit parts not supplied by themselves. I had a big argument with the call centre and then with the dealer saying that they were OEM parts supplied by an another Audi dealer and the only reason I didn't get the parts from them was because they were £200 more expensive. I eventually got a service guy to confirm that if I had an invoice and that they were OEM parts they would fit them. Incidentally I approached Zentrum who are Porsche independent specialists and they said the same.
I will give them a call and see what they can offer. But one on eBay....might be Crewe are listing £120 delivery which is madness. I have a mechanic friend who will fit them for me.
It is Crewe. Depending on how urgent you need them, I'll be taking my car there in 6 weeks or so. You could come to a deal to buy them, I'll pick em up and post at cost if needed.
Mike
Sent from my Nexus 5X using Tapatalk
Mike
