TERRACLEAN INTAKE CARBON CLEAN
nij
Re: TERRACLEAN INTAKE CARBON CLEAN
Post by nij » Tue May 16, 2017 5:46 pm
Rodney007 wrote:
Sat Apr 15, 2017 2:12 pm
Heres a vid of it on being done on a Jag with some carbon emissions tests before and after.
https://youtu.be/wiViPKIoG68
It does seem to work however I think a before and after tear down on an RS4 will put the topic to rest once and for all!
I would do it if there was such a service avail in NZ.
It physically impossible for it to work on direct injection engines like the RS4.
Unlike a conventional engine, fuel is injected directly into the combustion chamber. Therefore, it doesn't touch or pass through the back of the inlet valves where the carbon deposit has build up. The only benefit I can see is the fuel injectors, which should be cleaner due to this cleaning process.
Phantom Black R8 V10 plus, Capristo Exhaust
Phantom Black (B7) RS4 Saloon, MRC Stage 2
Mercedes E-Coupe 350CDi
Post by MikeFish » Tue May 16, 2017 7:44 pm
I had the enginecarbonclean (the h2o one) which pumps something like hydrogen and oxygen in through the air intake. There was a definite improvement in the smoothness of the engine when driving in traffic (similar to the benefit that I felt from an MRC carbon clean). Before the clean I had been taking logs of mass air flow as this is directly related to and therefore a good indicator of the amount of power being produced. I did the same after the clean. There was no increase in mass air flow. The improvement in smoothness may well have been due to the nuts being revved off it as part of the process as previously mentioned.
Dantheman84
Post by Dantheman84 » Tue May 16, 2017 9:50 pm
So this pumps hydrogen into inlet cleans carbon build up which then gets flushed into cylinders and out the exhaust ports
RS4 kw v3 full miltek no cats :nogarors4:
Intake spacer deflap stage 2 flat shift launch
Kawasaki ZX10R 197bhp :audibash:
Post by MikeFish » Tue May 16, 2017 10:20 pm
Something like that. MRC said my engine was proper dirty when they did the clean but there must have been quite a few miles and years between the cleans.
FaisalJ
Post by FaisalJ » Wed May 17, 2017 12:05 am
Whilst chatting to the guy remapping the TT track car, he mentioned that water + methanol injection has many benefits (mainly more efficient cooling of compressed air than an intercooler) but one of the benefits is prevention of carbon build up.
I wonder if anyone has tried this on the RS?
2007 RS4 B7 Avant
Post by MikeFish » Wed May 17, 2017 12:12 am
Tony Hayers did a water meth injection install on his B7.
Post by MikeFish » Wed May 17, 2017 12:14 am
FaisalJ
Post by FaisalJ » Wed May 17, 2017 10:04 am
Nice one Mike.
Shame he never reported back on that thread whether it made a difference to carbon build up
2007 RS4 B7 Avant
iconic78
Post by iconic78 » Wed May 17, 2017 10:25 am
FaisalJ wrote:Whilst chatting to the guy remapping the TT track car, he mentioned that water + methanol injection has many benefits (mainly more efficient cooling of compressed air than an intercooler) but one of the benefits is prevention of carbon build up.
It's something we looked at in detail-see the threads on AR & AZ. The gains are there but there's better ways to to reduce your IAT's especially on an FI car. High IAT's kill power - you seen this from running logs.
1) Replacing the PCV system with a separate catch can system
2) and install a "Killer Chiller".
You guys in the uk probably don't use your AC much anyways so this is best and easiest way to reduce temps, increase charge density and power output.
They produce a kit for Audi's as well.
iconic78
Post by iconic78 » Wed May 17, 2017 10:26 am
Also if you can run E85 that would reduce Carbon deposits.
iconic78
Post by iconic78 » Wed May 17, 2017 10:28 am
Aside from CC's having good injectors that flow properly is something a lot of people overlook.
Covkiller
Post by Covkiller » Sun May 21, 2017 10:21 pm
What is E85 ?
:biggrin2:
pule333
Post by pule333 » Sun May 21, 2017 10:33 pm
Covkiller wrote:What is E85 ?
:biggrin2:
Pretty sure it's some kind of energy drink or somethin
RS4 B7 aka Vinnie
Post by MikeFish » Sun May 21, 2017 10:50 pm
:biggrin2:
It's a BMW Z4.
Post by MikeFish » Sun May 21, 2017 10:51 pm
Or Ethanol fuel.
Users browsing this forum: Google [Bot] and 118 guests
