No boost .
Re: No boost .
Okay searched and got the imfo on the N80 evap . Also eml light is on now so hopfully get it scanned one evening or more than likely next weekend cheers .
Re: No boost .
Okal all , so i finally got my problem sorted , it was the n75 valve .
Whilst i was looking for boost leaks i removed the undertray and wheel arch liners to get a better view of things .
Inoticed the n/s cooler was soaked with oil every where so bit the bullet and ordered a pair of wagners .
I fitted these yesterday and they fitted perfectly including the shrouds , no trimming or anything so hats off to wagner
for a nice bit of kit .
The eml light was my bad as i had removed the cam angle sensor plug and not refitted it after changing the d/vs .
Re: No boost .
Cool. Sounds like a good result.
Re: No boost .
Thanks yes and as usual your diagnosis was spot on . So just an anoying slight oil leak to sort now on the drivers side cam cover , thanks for the help so far .
