Anyone running a cheap track car?
marc1
Re: Anyone running a cheap track car?
Post by marc1 » Thu May 04, 2017 2:38 pm
Maybe on the TT (which is a bargain!). You still don't want to kill them in a day. That said Pagid RS29's are usually about £250 a pair.
Discs and pads all round on the E36 floor r us was £460.
FaisalJ
Post by FaisalJ » Wed May 10, 2017 12:17 pm
Have any of you chaps tried an aftermarket wireless TPMS kit in order to monitor tyre pressures and temps?
There seem to be some that utilise internal sensors on the valve, and cheaper ones that use a new valve cap. Either way you get a display in the car with temps and pressure for all 4 corners as you're lapping!
2007 RS4 B7 Avant
FaisalJ
Post by FaisalJ » Wed May 10, 2017 12:21 pm
Version with internal TPMS sensors (must be better for temps):
2007 RS4 B7 Avant
Eddie555
Post by Eddie555 » Wed May 10, 2017 9:33 pm
Hey buddy. There's a partial postcode on the last picture. Edit please.
Current ride’s
Previous rides
Post by HYFR » Wed May 10, 2017 10:10 pm
Re TPMS, I'd say just get a digital gauge and check when in pits
FaisalJ
Post by FaisalJ » Wed May 10, 2017 10:27 pm
Eddie555 wrote:Hey buddy. There's a partial postcode on the last picture. Edit please.
Good call!
2007 RS4 B7 Avant
pule333
Post by pule333 » Wed May 10, 2017 10:30 pm
I though about getting some but decided not to right now.
Firstly the screw type, would be annoying to constantly undo to pump up or deflate. And for the internal once, it's a fair amount of cash since you have to unmount all 4 tyres. At best extra £60. So instead using handheld device for a tenner ;)
RS4 B7 aka Vinnie
FaisalJ
Post by FaisalJ » Wed May 10, 2017 10:40 pm
Screw you lot, I'm getting them Image
Bagged an unused pair of 245/45/17 nankang NS2R's for £80 on eBay. Going to order 2 more, get some lightweight 17's to mount them on, and so can do TPMS at the same time.
I was looking at team dynamics, OZ's etc and then stumbled across Autec Wizards (German brand). 8.6kg for a 17" rim vs 8.2kg TD pro 1.2, but only £430 for a set! Can you believe the stock TT wheels are 13.8kg!
Haven't sorted the wheels yet, but did order some coilovers. ST XA's - had never heard of them before; ST is a KW brand, and the XA is identical to the KW variant 2, but galvanised rather than stainless steel so cheaper.
2007 RS4 B7 Avant
Post by HYFR » Wed May 10, 2017 10:59 pm
Do they do those wheels in 18's for the TT?
1781cc
Post by 1781cc » Wed May 10, 2017 11:03 pm
Have you checked the load rating on the autecs?
FaisalJ
Post by FaisalJ » Wed May 10, 2017 11:15 pm
HYFR wrote:Do they do those wheels in 18's for the TT?
Yep!
£147 each from tyreleader but you might need spacers (ET35)
2007 RS4 B7 Avant
FaisalJ
Post by FaisalJ » Wed May 10, 2017 11:16 pm
1781cc wrote:Have you checked the load rating on the autecs?
They're load rated for vans, 600kg/wheel I believe
2007 RS4 B7 Avant
pule333
Post by pule333 » Wed May 10, 2017 11:20 pm
Have a look at Fondmetal. 9rr I think.
RS4 B7 aka Vinnie
1781cc
Post by 1781cc » Wed May 10, 2017 11:22 pm
Sweet, that should do it, good find at the price too!
FaisalJ
Post by FaisalJ » Fri May 12, 2017 12:15 pm
Balls. My coilover order is stuck in a backlog at the KW factory - not due to be sent out till 24th May :-(
The car's probably not going on track for a month though from late May to late June (during Ramadan), so I might stick it on axle stands on the drive and have a bash at fitting the coillies myself.
4 hours for a pro to fit them - 4 weeks for me? Sounds about right!
2007 RS4 B7 Avant
Users browsing this forum: No registered users and 118 guests
