Anyone running a cheap track car?
Re: Anyone running a cheap track car?
who did you book bedford with on the 29th mate? I might be up for that
MSV1781cc wrote:who did you book bedford with on the 29th mate? I might be up for that
Do it!
2007 RS4 B7 Avant
Nice one!! Looking forward to it1781cc wrote:Just booked it - see you there!
2007 RS4 B7 Avant
Donington 18th?))))FaisalJ wrote:Nice one!! Looking forward to it1781cc wrote:Just booked it - see you there!
RS4 B7 aka Vinnie
RS4 B7 aka Vinnie
Overall the TT was brilliant
10 ring laps and a 15min GP track session
R888 tyres are stunning and all day I never had any brake issues with the standard calipers with DS2500 pads, uprated fluid, goodridge lines and TTRS brake ducts
So, first trackday in the Turbo Tin-can with my mate yesterday, and it was great fun! Lots to learn though!
Big thanks to 1781cc/Lee for all the help and advice during the day.
A few thoughts...
Prep did not go to plan. Lack of a locking wheel nut key, or a locker removal socket that would fit, meant not all the pre-trackday jobs got done. Couldn't get the cookbots on, and spent so much time faffing around trying to get the lockers off that the TTRS ducts and haldex insert got neglected.
On track, the car felt more capable and quicker than I expected. I found I was a lot more committed than I have been on previous track days in my RS4. It was nice to not stress about doing damage to my pride and joy.
Really enjoyed the track at Bedford too - especially the lack of sh** to hit! I did have one off onto the grass - was pushing on and came into a corner too quick, too much steering input and lots of oversteer later I was going backwards onto the grass! Only my pride damaged.
A few issues/follow-ups:
1. Brake fade after about 15-20min. Hoping the TTRS ducts help in this regard when they go on. Also, need to check paperwork to see which performance brake fluid is in there at the moment, and when it was changed last.
2. The car seemed to lose power at 5.5-6k revs when hot; almost as if you'd hit the redline. Not sure if that's connected to no. 3 - or could be something else. Any ideas?
3. EML came on on the drive home. Scan showed an intermittent fault on the knock sensor (which I only just had changed, so might be an old code I forgot to clear) and catalyst system bank 1 efficiency below threshold (Could that just be due to the decat? Cleared the codes and will see what comes back.
4. Oil temp seemed to get quite high too, almost into the red zone on the gauge before I backed off and let the car cool. What's a typical on track temp for you guys?
5. We need more grip and better suspension! Having a passenger ride in Lee's awesome TT showed up the stock dampers/40 mm spring combo on our TT, and the slightly wider tyres on Lee's car really improve lateral grip. It felt a lot more planted. Perhaps the haldex insert makes a difference too.
6. Made a rookie mistake and forgot the tyre pressure gauge. I suspect I was running too high a pressure when the tyres were warm.
So, list of stuff to sort, then bring on the next one!!!
The other notable thing from the passenger ride was how much quicker the TT was on track than the C7 RS6 that was there!
A few thoughts...
2007 RS4 B7 Avant
Sounds like you had a good time. Will you be coming to Donnie on the 18th may?
Current ride’s
Previous rides
Previous rides
If I can get the afternoon off work and it's still available, yeah I will!Eddie555 wrote:Sounds like you had a good time. Will you be coming to Donnie on the 18th may?
2007 RS4 B7 Avant
Will be Awsome if you can make it! Glad car has proven it self on the track!! Would be fun to measure it up to my B7FaisalJ wrote:If I can get the afternoon off work and it's still available, yeah I will!Eddie555 wrote:Sounds like you had a good time. Will you be coming to Donnie on the 18th may?
RS4 B7 aka Vinnie
RS4 B7 aka Vinnie
I'm booked on to the 18th May now
2007 RS4 B7 Avant
RS4 B7 aka Vinnie
RS4 B7 aka Vinnie
Top man.
Current ride’s
Previous rides
Previous rides
Finally got the videos done, so thought I would post proof of my RS6 bashing ha ha
https://www.youtube.com/watch?v=hNwc37c ... eWhitehead
