Biggest Width Alloys
Re: Biggest Width Alloys
I've got a new non OEM set of wheels to go on mine and there 19x9.5j et35 if that helps and I know of a guy in the America that's putting 20x11 on the rear of he's !!
What wheels did you go for? Yeah, the 3sdm would still be et35 on the 9.5j as well, just concerned that the reason it says they don't fit is because they'll catch something in board? I don't think the extra poke would do anything outboard.
TheseMHooper16 wrote:What wheels did you go for? Yeah, the 3sdm would still be et35 on the 9.5j as well, just concerned that the reason it says they don't fit is because they'll catch something in board? I don't think the extra poke would do anything outboard.
can't for the life of me remember what there called I'll have to look on the paper work I've had them powder coated in a custom finish.i ask on here before and was told 9.5j with et 35 should be fine there is a "nobbly bit" on the alloy upright but I've ground mine back-there's a few threads on here if you have a look Sent from my iPhone using Tapatalk
Where are you looking to buy from? There are a couple of site sponsors on here - Prestige wheels (Birmingham) and Revolution (think Newcastle way). Get in touch with them and they should be able to help you out with fitment.MHooper16 wrote: ↑Tue Apr 25, 2017 11:49 amWhat are the biggest width alloys you can run on a RS6 C5 Avant? Looking at maybe getting a set of 3sdm 0.05s but worried that the 8.5j won't be wide enough to clear the front calipers without spacers but when ever I select the 9.5j width always comes back as this fitment won't fit vehicle? Any help or ideas?
Shouldn't have different sized wheels front to back on the '6 (unless tyre matching means they have the same overall circumference). It'll screw with the diffs otherwise.
Daytona RS6 Avant
Not to mention the ESP.
That's nice!!! Should have no issues with 9.5j then. Thanks
I know mate but you know what the yanks are like!Nobby wrote:Shouldn't have different sized wheels front to back on the '6 (unless tyre matching means they have the same overall circumference). It'll screw with the diffs otherwise.
Which rims are those? Got any more photos to see them better?
Manufactured by Borbet for Rinspeed.
In this angle i like them...
Theyre a bit like bimotos...and more easy to clean...
Mugello Blue C5 RS6 Avant
Viper Tuning ECU/TCU
Yellow Koni's
Yellow Koni's
They look good on the Porsche. Not sure about the C5. Maybe if they were a bit smaller.
Yeah from that angle they look great.
Users browsing this forum: Google Adsense [Bot] and 152 guests
