EXHAUST RECOMENDATIONS
coffey555
Re: EXHAUST RECOMENDATIONS
Post by coffey555 » Wed Mar 01, 2017 9:27 pm
I went for straight pipes because I was keen to keep the V8 burble. Others who have had an x-pipe say it retains the burble but I was not going to take any chances (the Quicksilver system had one).
The car now has a lovely deep engine note under load in a high gear, sounds epic further up the rev range and pops and crackles on the over run once the cats get hot after a good back road blast.
If you disconnect the vacuum pipes the valves are always open which makes cold starts a delight :-)
Think straight pipes are cheaper as well.
Misano Red RS4 B7 Avant
WRS4
Post by WRS4 » Thu Mar 02, 2017 11:52 am
MikeFish wrote:
Wed Mar 01, 2017 8:51 pm
They are sprung open. You need vacuum from the engine to close them. So if you disconnect the vacuum hose there is no vacuum to close them and the springs holds them open. Assuming they are not jammed closed that is.
I think cross pipe makes F all difference for power which is the point of having it. For noise I'd be surprised if there is a great deal of difference but somebody already said earlier it makes it more raspy.
cheers Mike
Sprint Blue RS4 - 20" X 10J 3DSM Wheels - Carbon Front Splitter - Carbon Rear Diffuser - H & R Anti Roll Bars - Bilstein Adjustable Shocks - Milltek Exhaust System - De Catted - Valve Removed - MRC Stage 2 Re-Map - 480 bhp
WRS4
Post by WRS4 » Thu Mar 02, 2017 12:41 pm
yes your right the straight pipes are cheaper which is always good lol, cheers for all the info im going with that option nice one :jump_clap:
denis.dasilva2
Post by denis.dasilva2 » Fri Mar 03, 2017 7:42 am
I run EBWERKS full 2.75" cats n DP
GT-steve
Post by GT-steve » Wed Apr 19, 2017 1:15 pm
coffey555 wrote:
Tue Feb 28, 2017 3:05 pm
Just remove the centre silencers and replace with straight pipes for around £200.
Where can I get this done? Mrc? Jcweldfab? Etc etc.?
Current: B5 S4 avant 283k miles Avus
Current: B7 rs4 avant Daytona
Prev: 2001 b5 S4 avant
jonytek
Post by jonytek » Wed Apr 19, 2017 1:20 pm
Are exhaust installer/center can do it and should't cost over £200. I used one of the chain companies and they did an ok job of it. Can't remember the name but I can check tonight if no one else beats me to it...
BUILD THREAD
IG: @bad_rs_4
jonytek
Post by jonytek » Wed Apr 19, 2017 1:35 pm
Here they are, I lose track of the UK workshops - https://www.longlife.co.uk/Longlife-Watford
Like I said, not the best engineers but they get the job done. Make sure they adjust the level of the back boxes/tips before they weld, mine are sitting slightly lower since having the work done...
BUILD THREAD
IG: @bad_rs_4
GT-steve
Post by GT-steve » Fri Apr 21, 2017 5:36 pm
Cheers for that... I contacted my local exhaust fabricators (not anyone that's been mentioned here) and they've quoted me £650 + VAT and they need the car for 2 days..
Seems a bit excessive :shock:
Post by MikeFish » Fri Apr 21, 2017 8:17 pm
They have either misunderstood what you are asking or are on drugs! I've had whole exhaust made up at one of these places several times and it takes about 4 or 5 hours (single branch exhaust though). To cut out 2 bits of pipe and weld 2 straight bits of pipes in it's place is a simple job.
Did they get underneath and look at exactly what needs to be cut out?
GT-steve
Post by GT-steve » Fri Apr 21, 2017 8:22 pm
Cheers Mike,
I didn't think it was me going crazy. I'll send him a reply email explaining his mistake.. He says he's done this conversion before quite a few times..!! ??
jonytek
Post by jonytek » Fri Apr 21, 2017 10:30 pm
Show them this.
BUILD THREAD
IG: @bad_rs_4
marc1
Post by marc1 » Sat Apr 22, 2017 8:10 am
Will take about an hour. Maybe an hour and a half.
marc1
Post by marc1 » Sat Apr 22, 2017 9:02 am
Or just buy this and as them to cut your stock exhaust to fit it.
https://www.ebay.co.uk/itm/132166349634
Orange.peel
Post by Orange.peel » Sat Apr 29, 2017 7:10 am
https://youtu.be/QRxouJapwhw this is my jcweldfab exhaust resonated and valved but there open in this part hold on to your ears lol
Users browsing this forum: Majestic-12 [Bot] and 151 guests
