New Grille Fitted
New Grille Fitted
I bought a "quattro" grille from Prospect Tuning on eBay after I was assured the grille would fit......it didn't, well not quite. There are a limited number of screw holes and some are not aligned with the frame. Easily sorted with a drill and certainly enough to keep it on securely. Secondly, the sensor apertures were slightly higher and had the cabling coming out the wrong way.....another quick fix. There were tabs all the way around which didn't fit either.....they all came off. Had to cut back the screw holes as well.
Was not happy about the grille issue, especially after the hassle of getting the bumper off! I may have been slightly hungover as well!! But, had waited long enough, in my eyes, to get this done so made lemonade as they say.
I wanted to fit spacers at the same time but had ordered the wrong front ones.....what a dumbass!!!
But, I am really happy with the new grille. If anyone is thinking of doing the same then I can certainly help out with what to do. I also know that not everyone is a fan of the "quattro" grille but to me it looks awesome!
......and yes, that is frost you see from this morning!!!
When not walking on water I fly through the air with the greatest of ease.
Re: New Grille Fitted
Got to love the whole blacked out look! Isn't the new grilles RS6 badge closer to the Audi rings than the original?
Current:
Former:
2016 R8 V10 Plus.
2019 E63s AMG 4Matic Estate.
2017 BMW M3 Competition Pack.
2015 A45 AMG.Overrated POS.
2016 C7 RS6 Panther black.
2006 BMW Z4M Roadster.
2004 Alpina Roadster.
1994 E34 M5 Saloon
Former:
2016 R8 V10 Plus.
1994 E34 M5 Saloon
yep its closer by 1 row apart form that looks good
2018 B9 RS4 Navarra Blue
2013 B8 RS4 Sepang Blue
2007 B7 RS4 Avant Sprint Blue
2001 B5 RS4 Nogaro Blue
1993 B4 S2 Avant laser Red
Not everyone's cup of tea but personally like the insert an Quattro badge on mine ! Good work
Good spot with the RS6 Badge. Might just leave it there to irk people!!
. I also wanted black rings and the grille came with those too so double whammy. One of the next jobs is to black out the matt chrome effect trim.
Thanks. The whole bumper removal was easier than I thought but still tricky for my level of DIY.Afsimba wrote:Not everyone's cup of tea but personally like the insert an Quattro badge on mine ! Good work
I'm doing this v soon but putting rings on and wrapping the outer grill. Main reason is to get the blades off...
Very uneasy about taking bumper off tbh with all the washer pipes / camera wiring - likely to break or scuff something no matter how prepared I am!
Current -
R8 V10 Plus
Previous -
C7 RS6 Merlin, JBS stg3
997 Gen2 PDK Turbo
Nissan GTR (JM900R)
B7 RS4 TTS, Sepang, black optics, ceramics, miltek, cold air feed etc etc / leon Cupra
, B5 RS4(avus), 996 GT2, B5 RS4 (Misano), TVR Cerbera 4.5, Evo VII RS Sprint
Nissan GTI-R, Uno Turbo ie
R8 V10 Plus
Previous -
997 Gen2 PDK Turbo
Nissan GTR (JM900R)
Once you get all the torx and 10mm bolts off, the bumper just pulls off. Grille has about 20 odd torx!! Plenty length in wiring to place the bumper on the ground after. For my job I left washer pipes attached and only had to take off front sensor. No front camera for me. These connections are easy to take off and put back in. Putting the bumper back on is tricky but straight forward enough. Take 5 rather than get pee'd off.E14STO wrote:I'm doing this v soon but putting rings on and wrapping the outer grill. Main reason is to get the blades off...
There is one 10mm bolt that has an access hole cut into the framework that can be tricky to get back in. Need the right angle to engage threads properly or you'll bugger them.
Give yourself plenty time as well! If you need anything then give me a shout.
Thanks. Does is slide back on nicely in guides and fit nice and flush.
I've taken B5 RS4 bumpers off before and never got them back quite how I wanted them! Old rusty fixings and tough to reach torx bolts
Current -
R8 V10 Plus
Previous -
997 Gen2 PDK Turbo
Nissan GTR (JM900R)
R8 V10 Plus
Previous -
997 Gen2 PDK Turbo
Nissan GTR (JM900R)
Mine went back on pretty easily. You'll need to manipulate it a bit. All the bolts and toe are easy, apart from the 10mm bolt you need the extension for.
It looks liek you did the job in the middle of the road!
That's what I thought!!
My bodywork man used a ramp to do my grille swap on my old car...he's an expert and it looked too hard for me to tackle!
RS6 C8 carbon black(merlin)
Panamera Turbo S e hybrid
RS6 C8 launch edition
R8 V10 plus
C7 RS6 PE dynamic pack plus
C7 RS6
Porsche Panamera Turbo
C6 RS6 AVANT
RS4 B7
Golf R32 mk 5
BMW M3 E46
Golf R32 mk 5
Golf GTI mk 5
VW Passat 130d 4 motion
VW bora 150pd
Ford Mondeo Ghia X V6
Ford Focus zetec
Rover 214!!
R8 V10 plus
C7 RS6
C6 RS6 AVANT
RS4 B7
Golf R32 mk 5
BMW M3 E46
Golf R32 mk 5
Golf GTI mk 5
VW bora 150pd
Ford Focus zetec
Rover 214!!
On a side road, residential area.MikeFish wrote:It looks liek you did the job in the middle of the road!
There are actually four 10mm bolts! The red arrow marked up photo shows location of tricky one, yellow the straight forward ones.E14STO wrote:Thanks. Does is slide back on nicely in guides and fit nice and flush.
Users browsing this forum: Google Adsense [Bot] and 75 guests
