Dab issue
Re: Dab issue
Have you cleaned the connection on your phone? Sometimes they get a build up of fluff/lint in there. Have you tried putting your phone into flight mode whilst connected?
- Surrey Sam
Re: Dab issue
Some good advice from the Chunk there, if all that fails then get an OEM AMI USB lead. They're not that expensive in the grand scheme of things.
Re: Dab issue
I'm going out in the car tomorrow chaps. Will give it a clean and see if it still messes up with it in airplane mode. Find it stupid as the 12v socket is for what if it's not "12v accessories" given there is the redundant ash tray and 12v lighter not 30cm away!
I have the cable in the glovebox but that's a right f'ing pane to plug in (passenger side visit each time!). I'd prefer something near me for when I get in and get out of the car.
Current:
- Audi B8 RS4 - Panther Black
Previous:
Previous:
Re: Dab issue
Make the glove box, the phone box. You've heard the advertsSammyb349 wrote: ↑Sun Apr 16, 2017 10:03 pmI'm going out in the car tomorrow chaps. Will give it a clean and see if it still messes up with it in airplane mode. Find it stupid as the 12v socket is for what if it's not "12v accessories" given there is the redundant ash tray and 12v lighter not 30cm away!
- Shinobi675
- 5th Gear
Re: Dab issue
This is exactly what I've got! It's only with DAB and I can't work out why it makes them sound blown!Surrey Sam wrote:Only problem I've ever had, is where listening to a couple of stations the front tweeter sounds like it is blown/popped (e.g. Kerrang). I put that down to the station, rather than the DAB.
I have it with all my DAB stations, nothing for FM, that sounds great.
Re: Dab issue
So it's definitely iPhone/iPad when connected to the 12v socket that causes my DAB to crackle and cut out intermittently.
The OEM connector in the glovebox is fine.
So annoying as I can't charge stuff while I drive if I want to listen to the radio (as of course Spotify doesn't work with Audi MMI)
Current:
Previous:
Previous:
Re: Dab issue
Amazon delivered a new 12v socket hobby to test to see if it was that and bingo ! It's the USB socket that has caused the issue.
Got my self a surge protection Anker job which has done the trick.
Current:
Previous:
Previous:
Re: Dab issue
Re: Dab issue
Current:
Previous:
Previous:
Mooney3019
- 1st Gear
Re: Dab issue
Yup same here I phone charger
Users browsing this forum: Google [Bot] and 183 guests
