TERRACLEAN INTAKE CARBON CLEAN
Re: TERRACLEAN INTAKE CARBON CLEAN
Post by chunky79 » Sat Apr 15, 2017 2:55 pm
It works on certain builds/type of engine.
Jon_J
Post by Jon_J » Sat Apr 15, 2017 3:44 pm
Like I said, has anyone done a dyno before and after? Surely it's in the companies interest to do this? If it cleaned it you would see an increase in BHP. Simple test!
RS4 B7 Sprint Blue
- Titanium Pack
- Black Optics
- B16's
- RNSE2 with AMI
- Reverse Camera
- Full Stereo install
S5 8T Cab White
A5 Cab 3.0 TDI Phantom Black
Post by chunky79 » Sat Apr 15, 2017 4:08 pm
Do a search on here.
Also check out tyre threads.
Also check out what fuel is best threads.
Brooner
Post by Brooner » Sat Apr 15, 2017 5:21 pm
yes there was some one on here looked into it properly and found that it does not clean the FSI Engine and the garage he spoke to couldn't connect the system up to the RS4
why i cant remember
Eddie555
Post by Eddie555 » Sat Apr 15, 2017 7:05 pm
It was Faisal that did the tests. On his Golf and his RS4. And in his write up he explained that this terribleclean was not worth a fivenuckleshuffle.
Current ride’s
Previous rides
Eddie555
Post by Eddie555 » Sat Apr 15, 2017 7:09 pm
Actually it wasn't Terraclean. But sounds the same.
viewtopic.php?f=35&t=117463&hilit=Terraclean+test
Ps. It's not hard to use the search button.
Current ride’s
Previous rides
Covkiller
Post by Covkiller » Sun Apr 16, 2017 5:26 pm
Why doesn't Terraclean dyno an RS4 B7, then take the inlet manifold off to view the carbon build up. Then put it back together, clean and repeat.
This for sure would show the results and if positive they would make a fortune from RS4 B7 owners alone. It's a no brainer for a company who has invested millions in their product. I would like to see how a full arshole cap of carbon is dissipated using their system.
I have used their outlet cleaning system which I believe is logical and for £85 I can afford it and with a proper MRC carbon clean to the inlets I get 448ps with no cold air feed, I am one happy bunny.
pule333
Post by pule333 » Sun Apr 16, 2017 7:33 pm
Covkiller wrote:Why doesn't Terraclean dyno an RS4 B7, then take the inlet manifold off to view the carbon build up. Then put it back together, clean and repeat.
Because it doesn't work on the Rs4 :) that's why
RS4 B7 aka Vinnie
Covkiller
Post by Covkiller » Sun Apr 16, 2017 8:22 pm
Exactly :drink:
FaisalJ
Post by FaisalJ » Sun Apr 16, 2017 9:21 pm
Yep - I tried and tested, all details on the forum, and vid on YouTube.
Had the manifold off shortly after the clean, and it was full of carbon.
I'll say that owners that report some improvement in driveability after one of the enginecarbonclean/terraclean aren't necessarily experiencing a placebo; the process does involve a lot of revving and injecting oxygen into the manifold, which should combine to get a really hot combustion and possibly clear some crap from cylinders on downstream. But you'd get the same effect doing an Italian tune! And that's a lot more fun.
The effect on the carbon in the inlet manifold just seem to be to make it a bit more wet and gunky than MRC were used to seeing. I had a clogged breather pipe, which may or may not have been caused by the enginecarbonclean. Once MRC had cleared it all up properly, I gained 44 horsepower.
2007 RS4 B7 Avant
jaysrs4
Post by jaysrs4 » Sun Apr 16, 2017 10:47 pm
Fcucking Twatterclean shattty <beep>
FaisalJ
Post by FaisalJ » Mon Apr 17, 2017 9:58 am
jaysrs4 wrote:Fcucking Twatterclean shattty <beep>
Actually, that's a better summary than mine!
Should be their company tag-line!
2007 RS4 B7 Avant
jaysrs4
Post by jaysrs4 » Mon Apr 17, 2017 10:36 am
Hehehe
hector8
Post by hector8 » Sun Apr 23, 2017 7:19 pm
There is a guy in Northern Ireland who I would trust to do a thorough clean.
His name is Robin and he works at MacMillan Porsche.
Macvoy motors wont do it as I am very friendly with his mechanic and even he recommends Robin.
I got a price from Robin last year it was around £650 + VAT.
He was willing to take before and after pics. He showed me a few from the Porsche's he does.
I am probably going to get him to do it very soon.
Second problem is , the 4wd rolling road over here aint 100%, I do plan to do a before and after but rolling roads for 4wd cars are never that accurate.
rs4pat
Post by rs4pat » Tue May 16, 2017 10:27 am
who has a 4wd rollingroad over here?
Users browsing this forum: No registered users and 164 guests
