Facelift Matrix
Facelift Matrix
I already have the pre-facelift matrix LED lights, i am considering buying the facelift headlights now and wondered if my existing ballast etc is interchangeable. I would assume it to be the same unit but just wondered if anyone could confirm
Re: Facelift Matrix
Not exactly clear on what you intend doing, but you do know that the headlights changed shape (subtly) at the facelift? The post-FL lights cannot be fitted to a pre-FL car without replacing body parts - I don't know exactly what, but I would guess the bumper and grille at the minimum.
Re: Facelift Matrix
What he said. Rear lights are interchangeable but the front lights won't fit without facelift front end.
Also, you have the pre facelift LED lights, they are not matrix though.
Re: Facelift Matrix
Pre 2015 facelift headlights weren't Martrix LED, just normal "All LED" headlights.
'15 B8 RS4 - SOLD
Re: Facelift Matrix
My mistake, I just assumed. With that much work involved not sure I would consider it now. Quite like the look of the pre-facelift lights. I bought the dynamic module for the rear and would quite like the front indicators to sweep too, that's all
Re: Facelift Matrix
You should have done it the other way round; bought facelift lights for the rear and got dynamic modules for the front if possible. Can you not use the rear modules for the front?
Re: Facelift Matrix
Mike I was under the impression that the rear face lift lights are very slightly different to the point they leave a gap. Can't remember where I read it but can lead to leakage.
Current ride’s
Previous rides
Previous rides
Re: Facelift Matrix
My Mrs new A3 s'line TDi FL has swooping rear lights but standard flashing fronts. I don't think it looks odd cause you can't exactly see both at the same time.
Current ride’s
Previous rides
Previous rides
