Hi,
I need some help please. If anyone happens to be going into their local TPS, would you be able to get me a price for a part I need?
Part # 4F0 959 455F -Radiator fan with control unit.
I'm based in Dubai and we don't have the luxury of alternative suppliers, only the main dealer. One of the main radiator fans has a problem with the inbuilt control unit and runs continually, even after shutting the car off. VCDS reports that there is an electrical fault with cooling fan #1
I've been quoted an astronomical amount for the part locally and to add insult to injury it's going to take three weeks to get here from Germany.
I normally manage to buy online and get the parts shipped here, I've got a drop ship address in the U.K, but I've drawn a blank on this.
PM me if you can help,
Cheers Rob
Help with TPS
Help with TPS
RS6, C6, 2009, MRC Stage 2, Aquamist Water/Meth injection, secondary CAT’s deleted, BMC Filters, Headlight Upgrade second projector with RS lens - Trupps supplied the parts I built myself. Interior LED upgrade, C7 RS gear knob upgrade, AutoTecknic Shift Paddle Extensions, KW V3 Coil-overs, H&R ARB's, H&R spacers 8mm Fr & 10MM R.
On the cards - Primary CAT delete, TTE Turbos
Re: Help with TPS
After taking it apart last night I found its not the fan that's the problem.
Re: Help with TPS
I'd advise to share your findings as it may help someone else on here suffering the same demise.
Users browsing this forum: Google Adsense [Bot] and 69 guests
