TPMS question
Audi Pardner
TPMS question
Post by Audi Pardner » Tue Apr 04, 2017 1:05 pm
Guys
Just put my 20" rims on for the summer and got 3 bleeps on starting the car and an error warning on the display - red/orange tyre cross-section image with an exclamation mark and 'tyre pressure too low' message. Normally when I swap over from the 19" to 20" wheels I get the re-set message.
Checked the pressures and they're fine. The wheel sensors were replaced last year so it's unlikely to be them, so I'm thinking it'll be the antenna behind the honeycomb rear bumper grille. This seems to correspond with old threads on here which suggest that the antenna may be buggered.
Is there anything else I should look at before I start poking around behind the grille and buying a new antenna? :audibash:
Misano Red B7 RS4 Avant. 20" Rotors. KW adjustable spring kit. 8 & 10mm H&R spacers. MRC Stage 2 remap. Pre-cat delete & x-pipe.
MrHilario
Re: TPMS question
Post by MrHilario » Tue Apr 04, 2017 1:55 pm
Just turn them off, they can be coded out with the Vagcom wizadry
1.4 Fiesta (Silver)
2.8 VW Bora V6 4motion (Blue)
4.2 Audi RS4 B7 Avant (Black)
Re: TPMS question
Post by MikeFish » Tue Apr 04, 2017 7:07 pm
Have you tried putting the other wheels back on to see if that cures the problem and therefore eliminating the antenna?
Audi Pardner
Re: TPMS question
Post by Audi Pardner » Tue Apr 04, 2017 8:35 pm
Good thinking Mike. I'll try it tomorrow.
Re: TPMS question
Post by Shoppinit » Wed Apr 05, 2017 5:22 pm
Did you relearn the pressure? Surely you woudln't get a low pressure warning if there wasn't communication. Vagcom will tell you either way.
psglas
Re: TPMS question
Post by psglas » Wed Apr 05, 2017 10:37 pm
I think I had a similar issue when I replaced the sensors on my winter wheels. See this thread
viewtopic.php?f=35&t=116898&p=763588#p763588
Try accessing the wheel change menu after leaving the ignition on for 30 seconds but don't start the engine.
Audi Pardner
Re: TPMS question
Post by Audi Pardner » Fri Apr 14, 2017 7:06 pm
Well I've finally got round to looking at the prob again.
Put the 19" standard wheels back on and no difference, so it's not a wheel sensor issue.
I can't access the display to try the wheel change option, it doesn't activate when I press the 'set' button on the steering wheel.
So I'm thinking it must be the antenna that needs replacing (as I want to keep the TPMS function).
Unless anyone knows what else it could be? :drink:
psglas
Re: TPMS question
Post by psglas » Fri Apr 14, 2017 7:43 pm
I'm pretty sure I had the same issue. Make sure and turn the ignition on for at least 30 seconds without starting the engine before trying to access the menu.
Re: TPMS question
Post by Shoppinit » Fri Apr 14, 2017 7:58 pm
If you've got a Vagcom you can test each one individually.
Audi Pardner
Re: TPMS question
Post by Audi Pardner » Tue Apr 18, 2017 8:17 pm
Spot on mate. I'd not previously left it on for about 30 secs when I'd tried to reset, but just done it now and it's cleared. Thanks, and a virtual pint :drink:
Thanks to others for suggestions too.
Users browsing this forum: Google [Bot], Zyox and 242 guests
