aviator help
aviator help
Ive shrunk a picture ready for my aviator but when i go into edit it i can see where to put it. I see where it tells me the size it needs to be but where do you insert it...?
Ta....
Ta....
Re: aviator help
I tried recently but couldn't find it either. Didn't spend a bunch of time on it but I have a feeling something's happened during the last site update. Maybe let Phil know.
Re: aviator help
I think you might be right
- Surrey Sam
Re: aviator help
Well you have an RS4 Avatar there as of right now?
Re: aviator help
It gives you an option to select RS4 etc but not to post your own. I thought it would do for now.
- Surrey Sam
Re: aviator help
I'll try have a go tomorrow, as I didn't get that far down my to do list.
Have you tried hosting the image elsewhere and then inputting the url?
Re: aviator help
As you can probably see, the URL trick worked in the signature... thanks Sam.Surrey Sam wrote: ↑Fri Mar 31, 2017 9:36 pmI'll try have a go tomorrow, as I didn't get that far down my to do list.
- Surrey Sam
Re: aviator help
No problem.
I've just tried the Avatar and as you can see, it works fine. You need to ensure that the image is maximum 80 x 80 pixels and the file size no larger than 100KB
Re: aviator help
All i was getting was the default rs options, could not see any where to paste my pic....Surrey Sam wrote: ↑Sat Apr 01, 2017 7:23 pmNo problem.
- Surrey Sam
Re: aviator help
In the Avatar section, you need to go to the Avatar Type drop down menu and select Upload Avatar. Then go to the box underneath and hit the browse button, find your saved Avatar image on your hardrive and choose that. Then press Submit at the page bottom. If it meets the size criteria I mentioned earlier, it will then upload and be displayed.
