Wheels changed giving error message on DIS
Ozzyz
Post by Ozzyz » Tue Mar 28, 2017 8:22 am
Since I've changed my wheels I have kept on getting this error message coming up on the DIS screen. I checked the manual and it's saying the message can come up when the sensors doesn't recognise the new wheels or if the wheels do not have the TPMS, which mine do not.
Has anyone else had this symbol come up once changing wheels? Image
rickster147
Re: Wheels changed giving error message on DIS
Post by rickster147 » Tue Mar 28, 2017 8:29 am
If you have no sensors it will think the tires are flat I presume
Think you will need coding to disable them
Rs4 b7 In avus silver with b14 Bilstein coilovers, centre resonator delete with x pipe and piggie cats gutted
Headlights detangoed trups led kit drl reverse and numberplate kit
Previous audi
rs6 c5 - mrc stage 2 remap-itg filters-forge dumpers-center decat with miltek kw coilovers- h and r
I call her the growler lol
jonytek
Post by jonytek » Tue Mar 28, 2017 9:02 am
Yep, you'll just need to code them out. Do you have a VCDS cable?
BUILD THREAD
IG: @bad_rs_4
Post by MikeFish » Tue Mar 28, 2017 9:47 am
Not sure what you are looking for? You've got a message for no TPMS and you have no TPMS. Everything working as it should.
Incidentally I'd have expected a non communication error rather than a flat tyre symbol; from memory it says TPMS in red letters, but if you've checked the manual and that's what it says you are all good.
If you are asking how to get rid of it, Jony has the answer, you need VCDS to change the coding. Or buy some sensors for your new wheels. Or live with the error.
Ozzyz
Post by Ozzyz » Tue Mar 28, 2017 9:47 am
Oh that's ok then, I'll just keep and eye on the tyre pressures in that case.
I don't have VCDS to code it out unfortunately
Ozzyz
Post by Ozzyz » Tue Mar 28, 2017 10:07 am
MikeFish wrote:Not sure what you are looking for? You've got a message for no TPMS and you have no TPMS. Everything working as it should.
I was asking if anyone else has had the same symbol come up when they've changed the wheels over as a lot of guys on here have different wheels on their cars.
RS04YOB
Post by RS04YOB » Tue Mar 28, 2017 11:22 am
I had the same its easy enough to cancel the warning if you get chance to use a VCDS
Starry
Post by Starry » Tue Mar 28, 2017 11:23 am
Mines the same after I changed to 20's. Still not got around to coding it out yet. New tyres going on next week so I'll sort it then.
2006 RS4
Phantom black
mikep99
Post by mikep99 » Tue Mar 28, 2017 11:27 am
for info. - to code out the TPMS warning, in VCDS:
Select -> 17-Instruments -> Adaptation -> Channel 61.
Subtract 512 from whatever value you find there.
ta
Mike
R-S-4
Post by R-S-4 » Tue Mar 28, 2017 12:18 pm
i had the tpms taken out of the original wheels and put in my new wheels, never got a message code, worth a try
Sprint blue, Stage 2 Re-Mapp, Milltek Cat Back Non Valves Non Resinated, De Catted, Overrun/Downshift Crackle, DeFlapped, Performance Filter, H & R front & rear roll bars, bored out manifold ports, bilstein coilovers, 15mm spacers all round, 20" 3DSM wheels 10j, Carbon front splitter & rear diffuser, window tints rear 5% - rear side 20% - side 35%.
MB2
Post by MB2 » Tue Mar 28, 2017 12:36 pm
I had the exact same symbol when my TPMS antenna died so I think the DIS doesn't have a massive repertoire of symbols. TPMS for TPMS failure would be much more helpful but at least on some DIS (mine is 06) I don't think you get this.
Post by MikeFish » Tue Mar 28, 2017 1:20 pm
I thought when I put my 20s on I got a red TPMS on the DIS until i got some new sensors fitted. Could be wrong but that symbol above doesn't look familiar.
MB2
Post by MB2 » Tue Mar 28, 2017 10:50 pm
Others have mentioned TPMS but I have only seen the tyre symbol (also red when flat) so I think it may depend on the car or possibly even the actual error it sees.
Starry
Post by Starry » Tue Mar 28, 2017 11:08 pm
Maybe red indicates a puncture and yellow is a drop in pressure but yellow with a line through it means no signal from the valve sensor to the receiver. Obviously due to the new wheels not having them.
2006 RS4
Phantom black
MB2
Post by MB2 » Wed Mar 29, 2017 1:00 pm
That could well be it - I have had red and yellow before for low pressure but don't remember if had the line through it - would make good sense if not. I definitely had yellow with the line through it when the antenna was down so no communication just as the OP has with no sensors nearby.
Edit - looked in the Quick Ref and there it is - Yellow tyre with a line through it = Tyre Pressure Monitoring System not available & Yes Yellow and Red Tyres with no line for Loss of Tyre Pressure or Tyre Pressure too Low.
Users browsing this forum: Bing [Bot] and 102 guests
