Siren noise!!!???
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
clubsport
Siren noise!!!???
Post by clubsport » Wed Sep 14, 2005 8:49 pm
Only just noticed but I appear to have a noise similar to a distant police siren...I get this starting at around 1500 rpm.
Car runs fine...I seem to be getting 25+ MPG (standard) but there is this siren like whizzing/whoosh noise...not overpowering just there!
Having read through the forum I get the impression it could be a pipe leak, other than checking the DV's and "F" pipe is there anything else that may be the cause....or is this nothing to worry about?
Thanks for your wise words :)
Julesm
Post by Julesm » Wed Sep 14, 2005 9:36 pm
I may be wrong but a siren type noise is usually associated with possible turbo wear :cry: ........do a search using "siren".......
dazzer
Post by dazzer » Wed Sep 14, 2005 10:00 pm
Is it more prevalent when the engine is cold?
dazzer
Post by dazzer » Wed Sep 14, 2005 10:02 pm
eddiecrawford
Post by eddiecrawford » Wed Sep 14, 2005 10:31 pm
does the siren take a few seconds to stop/slow down after engine turned off?
if so, one of front electric fans has failed or is jammed with a bit of cabling. makes one of the others go twice as fast, hence noise
ignore this if it does not happen as above...
clubsport
Post by clubsport » Thu Sep 15, 2005 8:00 am
Thanks for the replies chaps, It only appears on light acceleration, sounds like turbos spooling as they come in at 15-1800rpm....maybe normal....there are no noises on tick over or after the engine is turned off.
No oil is being used or signs of smoke, the engine rarely gets pushed above 3-3500rpm.
KayGee
Post by KayGee » Thu Sep 15, 2005 9:24 am
My turbos weren't noticeable until I put on DP's and catback now can here them clearly. Turbos sound like dentist drills when knackered.
NeilMc
Post by NeilMc » Thu Sep 15, 2005 9:24 am
In the words of the infamous VandyS4 (with regard to turbo failure): If you're not sure if you have the siren noise, you don't have it, it sounds like 10,000 screaming babies in the engine bay.
All turbos make a slight siren noise when spooling, I wouldn't worry too much about it.
2000 Nogaro S4 Saloon
clubsport
Post by clubsport » Thu Sep 15, 2005 10:21 am
Thanks, having also run a "siren search" on this forum, I have now concluded it is completely normal....just wondered, all part of learning about these cars.
maxxximus
Post by maxxximus » Thu Sep 15, 2005 11:47 am
clubsport wrote: the engine rarely gets pushed above 3-3500rpm.
Youre clearly not gettin the best out of your motor. When warm the engines designed to be driven hard.
As for turbo noise - youll know when theve blown
clubsport
Post by clubsport » Thu Sep 15, 2005 2:42 pm
I enjoy the torque and never rev it really, characteristics of a lazy V8!
(i know it's a blown V6 :) )
Never thought the turbos were giving up, just wondered if it meant there was some pipe leak somewhere.
I must try to get the car on a Vag com diagnostic reader sometime, just for peace of mind
stan
Post by stan » Thu Sep 15, 2005 10:16 pm
Mine's been doing it since I bought it 3 years/40000 miles ago. For the first few weeks I kept looking for the blue flashing lights.
Jez
Post by Jez » Thu Sep 15, 2005 11:02 pm
One of my turbos whines. It's noticable when the engine is cold, but still present when warm. Starts at 1800 rpm then fades out at 3000 rpm.
Think I might start putting some money aside for when it decides to give up the ghost...
Users browsing this forum: No registered users and 40 guests
