Fixing front number plate - options?
E14STO
Post by E14STO » Fri Mar 03, 2017 10:25 am
Hi,
I've had a quick search and there seem to be 4 options -
1/ Cut down the old holder - I assume given the screw fixings this is just a case of trimming of the sides. Not keen on this tbh. Might look a bit scruffy
2/ new holder, smaller, not sure how to get These or if my plate would fit - any companies do them with various sizes?
3/ attach by other methods - I'm struggling to see how Velcro / pads would work as there are no flat surfaces and this part behind the grill is solid so you can't secure round the back
4/ get a matching screw thread that secures the holder but needs to reach to sunken thread and screw the plate straight on
I'd prefer to do option 4 but not sure if hardware is available or what is behind the grill if screws are too long!
Current -
R8 V10 Plus
Previous -
C7 RS6 Merlin, JBS stg3
997 Gen2 PDK Turbo
Nissan GTR (JM900R)
B7 RS4 TTS, Sepang, black optics, ceramics, miltek, cold air feed etc etc / leon Cupra
, B5 RS4(avus), 996 GT2, B5 RS4 (Misano), TVR Cerbera 4.5, Evo VII RS Sprint
Nissan GTI-R, Uno Turbo ie
Iain
Re: Fixing front number plate - options?
Post by Iain » Fri Mar 03, 2017 11:06 am
I went with option 1 - I cut the ends off mine to keep the original screws in place....
Originally looked at options 3, but encountered the same issues as you!!
2018 Brabus G63 Widestar
2015 RS6 - with Added Milltek
2015 RRS - utter sh1te
2010 X5 4.0D M Sport
2009 R8 V10 Manual
2004 Lambo Gallarado Manual
3 x 997 C4S / C2s
2006 RS4 Avant
2001 RS4 - R500 FOR
1990 Dimma Cosworth H20 COS
2003 996 DMS Turbo
multiple 205's Dimmas
Scotty C
Post by Scotty C » Fri Mar 03, 2017 12:26 pm
I chose option 1 and cut a section off both ends very carefully using a fine toothed saw then glued the edges back together, and with a little help from some gaffa tape, which is now hidden under the plate, it looks acceptable in my opinion.
Current: 2019 BMW Alpina - B5 Bi Turbo Touring
Current: 2014 Land Rover Defender 110 All Black
Previous: 2017 RS6 Performance - Misano Red with Black Styling Pack
Previous: 2014 RS6 - Misano Red
Previous: 2004 S4 Avant - Nogaro Blue
Previous: 2001 S3 Absolute Red
E14STO
Post by E14STO » Fri Mar 03, 2017 12:38 pm
Thanks guys.
I was going to cut the ends of, take a segment out at either end and the glue the end s back on to main piece.
I didn't think the lugs that go in the grill would be missed given the centre one would still be there and the screws do the main job of Fastening it to the grill.
The cut has to be v accurate though although I think it would sand some for a better fit
Current -
R8 V10 Plus
Previous -
997 Gen2 PDK Turbo
Nissan GTR (JM900R)
Scotty C
Post by Scotty C » Fri Mar 03, 2017 12:54 pm
Yep - no lugs and the screws do the job perfect. I bought a new blade and just hoped for the best !
E14STO
Post by E14STO » Fri Mar 03, 2017 12:57 pm
Blade for a hacksaw? Fine blade for plastic / wood?
Everything I hacksaw tends to end up "s" shaped :-)
Current -
R8 V10 Plus
Previous -
997 Gen2 PDK Turbo
Nissan GTR (JM900R)
Post by MikeFish » Fri Mar 03, 2017 1:00 pm
E14STO
Post by E14STO » Fri Mar 03, 2017 3:29 pm
Thanks Mike. I've read that thread.
Doesn't really help me understand how to fix it without the mount.
And the part for the smaller holder is too small for my plate I think.
Current -
R8 V10 Plus
Previous -
997 Gen2 PDK Turbo
Nissan GTR (JM900R)
skirs6
Post by skirs6 » Tue Mar 07, 2017 12:08 am
E14STO
If your plate is 5 numbers/letters or less it will fit the smaller plate holder it takes a 360mm x 110mm plate which is standard uk height but reduced width
E14STO
Post by E14STO » Tue Mar 07, 2017 10:19 am
E14STO
Thanks - where are these purchased from? OEM or free market options?
Was reluctant to hack the original so just stuck the plate on the existing holder for the moment.
Current -
R8 V10 Plus
Previous -
997 Gen2 PDK Turbo
Nissan GTR (JM900R)
E14STO
Post by E14STO » Tue Mar 07, 2017 10:20 am
My plate is my signature so 6 digits.
Will measure plate later to be sure of size
Current -
R8 V10 Plus
Previous -
997 Gen2 PDK Turbo
Nissan GTR (JM900R)
skirs6
Post by skirs6 » Tue Mar 07, 2017 6:51 pm
Yours will fit on a 360mm plate. I just measured mine. If you stick to the normal size letters numbers each one is roughly 50mm. I have to Phone Demon plates as they don't show that size plate on their website as it's not an official size according to the very boring number plate rules
E14STO
Post by E14STO » Tue Mar 07, 2017 7:05 pm
Mine is 410mm, but I could trim it down at the edges to be 360mm
Just need the mounting bracket
Current -
R8 V10 Plus
Previous -
997 Gen2 PDK Turbo
Nissan GTR (JM900R)
