Backbox/muffler delete
Re: Backbox/muffler delete
So did you wrap the perforated pipe and then put the wool back in ?
Clio 172 cup Track Car (AST 5200, cage, Carbon seats etc.)
2.0 Locost - Part finished
Old English White '68 4.2 E Type - current
Daytona B7 RS4 MRC Stage 2 - current
Sapang C6 RS, MRC Stage 2 - current
e91 Lci 335d - Gone
Daytona C6 RS6 Stock - Gone
Avis B5 RS4, Milltek, Brembo 18z and MRC 440ps and 660nm - Gone
DPB Mk5 Golf R32 - Gone
e91 Lci 335d - Gone
Yup.GBR1198 wrote:So did you wrap the perforated pipe and then put the wool back in ?
I actually got Paul back round to open it back up again and cut into the pipe that had been welded around the perforated inner pipe which has now eliminated the drone completely but when accelerating, still sounds good.
I'm much happier now.
How are you finding yours?
Daytona Grey C6 RS6 Avant
Ebony Black C5 RS6 Plus - Gone
discostu49
Why did you put the wool back in ?
I'm guessing it's to do with keeping the sound quality close to stock and not tinny at all.discostu49 wrote:Why did you put the wool back in ?
It will probably help with keeping noise out of the inside of the car.
- Ciscokid_London
Thought I would share my exhaust combination - SuperSprint Decat, Quicksilver tailpipes - Loud on chokes as you would expect, deep drone for normal driving (but quite inside with the windows closed), loud exhaust pop between gear shifts (assume that's because of the decats, or the BOV's are getting old)
AUDI RS6 Sedan - REVO STAGE 2, SuperSprint Decat, Quicksilver Exhausts, Niche 20" Wheels
Matte Metallic Grey Wrap
AUDI RS6 - Current
EVO FQ-400 #35 - Current
Scooby Blobeye - Current
BMW M6 - Current
Audi R8 V10 - Previous
AUDI RS6 - Current
BMW M6 - Current
Have anyone tried this with fixing the pipes aswell inside the muffler?
Is that something that can be done at home via VCDS or does it, indeed, need to be done by MRC or similar shop?IanH755 wrote:The 30-45 second long cold start can be mapped down to 2-5 seconds my MRC or alternatively start the car, switch it off immediately and then restart it. That also stops the cold start feature.
I quite enjoy annoying the neighbours early in the morning if I'm honest.
c6 rs6 avant- mrc stage 2 -current
bmw e61 m5 saloon
s3 8p stage 2
vw bora tdi hybrid turbo
bmw e61 m5 saloon
s3 8p stage 2
It's a map change so MRC etc, however the "switch it on/off again" method works for freeUngjaevel wrote:Is that something that can be done at home via VCDS or does it, indeed, need to be done by MRC or similar shop?IanH755 wrote:The 30-45 second long cold start can be mapped down to 2-5 seconds my MRC or alternatively start the car, switch it off immediately and then restart it. That also stops the cold start feature.
Switch on/off or start engine/off?IanH755 wrote:It's a map change so MRC etc, however the "switch it on/off again" method works for free
Sorry, just to be clear - Switch the engine on (1st time) and then immediately switch it back off, then when you switch the engine on again (2nd time) there will be no cold start.
Mine being a straight piped all the way through, is too noisy although I do get a few
i just can't find myself appreciating the
it makes. I will want to get the backbox modified I suppose to dampen the noise.
it makes. I will want to get the backbox modified I suppose to dampen the noise.Re: Backbox/muffler delete
I appreciate this is an old thread.
Q - has anyone left the rear muffler and removed the silencer instead? Any feedback welcomed.
Adam
RS6 Wagon - C6
RS6 Wagon - C6
- Badassgermanlook
Also appreciare this is an old post but @longman h, just trying to understand exactly what you did to you exhaust. Removed secondary cats, cut open backboxes and removed wool then wrapped perforated pipe before welding back together?longman h wrote: ↑Tue Aug 23, 2016 10:03 pmYup.GBR1198 wrote:So did you wrap the perforated pipe and then put the wool back in ?
Audi RS6 V10 Avant
I have MIJ custom built exhaust... cats removed together with rear silencers - straight through pipes.
Very nice note when driven on motorways but it does have that droning sound that is tad annoying when driven in low gears / revs.
2008 RS6 Avant (Monza Silver)
- H&R ARBs
- H&R ARBs
Users browsing this forum: No registered users and 19 guests
