Hi Stuart, just wondered if there were any further updates on this? It's something I would be pretty I terested in.Stuart SWA wrote:Just a quick update, We have a very intermittent running issue with one of our current the test cars ( belongs to a customer and numerous Audi dealers cannot fix at present ). As soon as it is fixed we will post the results.
RS6/RS7/S6/S7/4.0 TFSI induction kit
Re: RS6/RS7/S6/S7/4.0 TFSI induction kit
- Stuart SWA
- Trader (Expired)
Car are all sorted now, we ended up fixing it our selves and claiming from Audi. I have been playing around with the kit on both cars but with the current weather our ambient temps are really low and I don't believe it gives a true reading for the UK climate. All I will say is they are consistently lower in everyday use than a stock airbox car in the present weather with or without a heat deflector on the engine side. The only time we see a rise is in stop/start traffic for long periods.
I promise I will post up some pictures/videos soon but I want to be sure of my findings in some warmer outside temperatures. Roll on spring.
Thanks Stuart
Thanks Stuart
Needmorespace
- 1st Gear
I made something similar after messing around with different bends. The Roc Euro style configuration had an extra bend and looked a bit less organised. I am also an engineer but went for noise so not too worried about power. Guess power not changed much without a remap? I made a basic head shield from aluminium firewall material with rubber foot seal edging. It's sounds great. Bit worried about water saturating the filter in Scottish weather
Needmorespace
- 1st Gear
Hi Stuart, have you made any further progress on testing the induction kit? I am still very interested in this addition.Stuart SWA wrote: ↑Fri Feb 03, 2017 2:34 amCar are all sorted now, we ended up fixing it our selves and claiming from Audi. I have been playing around with the kit on both cars but with the current weather our ambient temps are really low and I don't believe it gives a true reading for the UK climate. All I will say is they are consistently lower in everyday use than a stock airbox car in the present weather with or without a heat deflector on the engine side. The only time we see a rise is in stop/start traffic for long periods.
Thanks Stuart
Regards
Shane
Ha. Good old Stuart.
