Deano's B8 RS4
DeanoC
Re: Deano's B8 RS4
Post by DeanoC » Sun Jan 22, 2017 2:53 pm
Soooo much better!
Main suspects were electrical connections, whole memory seat module moved around, the interior door handle LED, the join with the B&O tweeter, the contact point between the cheapy plastic around the grab handle and the door card.
DeanoC
Re: Deano's B8 RS4
Post by DeanoC » Thu Feb 02, 2017 8:54 pm
Time to make some noise in a couple of weeks:
I'll do before and after dyno runs and record it for those thinking about a change.
noidea
Re: Deano's B8 RS4
Post by noidea » Thu Feb 02, 2017 9:29 pm
Is that Res or non Res?
Be interesting so see the results. Are there any claimed figures?
DeanoC
Re: Deano's B8 RS4
Post by DeanoC » Thu Feb 02, 2017 9:53 pm
noidea wrote:Is that Res or non Res?
Non res. No stats posted officially. Some tests have shown 10-15bhp but i just want to make aure it doesn't drop to be honest
noidea
Re: Deano's B8 RS4
Post by noidea » Thu Feb 02, 2017 9:58 pm
Is a non Res much louder?
The car I am picking up in 3 weeks has a Res system and that sounded good to me without being much different to standard.
I just wonder if it would get on on your nerves after a while if it drones.
DeanoC
Re: Deano's B8 RS4
Post by DeanoC » Thu Feb 02, 2017 10:01 pm
noidea wrote:Is a non Res much louder?
We'll soon find out. Everyone said the res is pretty much the same as the sports exhaust so i thought I'd give this a go. With the valves you should be good as long as you don't drive around at 40-50 in 7th
Outtlaw
Re: Deano's B8 RS4
Post by Outtlaw » Fri Feb 03, 2017 9:26 am
Good read and I like what you have done.
Exhaust is going to be interesting so look forward to seeing the end result :thumbs:
DeanoC
Re: Deano's B8 RS4
Post by DeanoC » Fri Feb 10, 2017 4:47 pm
I've been up to a bit of wrapping of the badges. I gave up looking for genuine carbon ones and these come out way better than expected!
I had a bit spare so did the keys:
daytonamart
Re: Deano's B8 RS4
Post by daytonamart » Fri Feb 10, 2017 5:07 pm
Erm........ so this is a good job!
Well done both keys and rings look spot on, where did you get the sheets of carbon from?
Gone B7 RS4 Sprint Blue Avant
Gone B7 A4 Reflex Silver
DeanoC
Re: Deano's B8 RS4
Post by DeanoC » Fri Feb 10, 2017 7:51 pm
daytonamart wrote:Erm........ so this is a good job!
Thanks. I did it once as practice then stripped it off and went for the final version which come out well.
I just got it off ebay. 3M scotchprint 1080
DeanoC
Re: Deano's B8 RS4
Post by DeanoC » Wed Feb 15, 2017 7:35 pm
I got the Milltek non-resonated today.
Very strong showing before and after:
noidea
Re: Deano's B8 RS4
Post by noidea » Wed Feb 15, 2017 9:30 pm
Was that just from the non Res?
More importantly what does it sound like!?
DeanoC
Re: Deano's B8 RS4
Post by DeanoC » Wed Feb 15, 2017 9:37 pm
noidea wrote:Was that just from the non Res?
More than ily what does it sound like!?
Yes no tuning just the exhaust.
Sounds bloody savage. Valves shut is like valves open on the sports exhaust but a bit more raspy with no more volume.
Valves open is really deep at low rpm and get raspy and loud as you rev it
Re: Deano's B8 RS4
Post by MikeFish » Wed Feb 15, 2017 9:45 pm
Wow that's a big difference on a NA car for just a cat back exhaust! Or was it a decat? I assume if it was decat you'd have had a map done too.
And it is not a correction error, there is 20bhp difference at the wheels.
DeanoC
Re: Deano's B8 RS4
Post by DeanoC » Wed Feb 15, 2017 10:40 pm
MikeFish wrote:Wow that's a big difference on a NA car for just a cat back exhaust! Or was it a decat? I assume if it was decat you'd have had a map done too.
Tell me about it. It suprised us all. They are a specialist known to me with a good reputation locally and i made it absolutely clear i wanted no faffing about with the numbers. They did not supply the exhaust so had nothing to prove or achieve. I wanted a clean before and after because i was worried about it messing up the back pressure and low down torque. It a decent dastek dyno.
It's cat-back. The single cat on the end of the headers remains and was untouched.
The OEM pipe is quite shockingly designed when you get up close. It has dozens of kinks and dents in it.
I have just been out for an hour in it and it is 100% noticeably quicker and fcuking christ is it loud!
Return to “Readers' Rides”
Users browsing this forum: No registered users and 39 guests
