Hello
If I purchase a TT RS steering wheel , could someone confirm the wheel code needed to swap into my RS4 (which has the MFSW currently, sport button on dash)
8J 4F0 419 091 CB
or
8J0 419 091 N
Secondly, what airbag is needed please??
Re: TT RS steering wheel
I fitter a TT RS wheel in December, I didn't have to use any codes and was a 10 min swap over along with The TT RS airbag
If you have the button on the dash then it is a straight swap.
You would be better off buying the wheel complete with the airbag. Buying them seperately is expensive and you run the risk of connectors/ looms being damaged as a wheel that is sold without an airbag has usually had an impact and little car is taken in removing the nackered bag
Thanks.
The codes I am asking about are the part numbers of the TT RS wheel.
Is there just one version of it. In otherwords if I buy a TT RS wheel with airbag it will fit.
Will try and get one with the airbag then. Cheers.
You want the steering wheel from a manual TT RS as I believe some were manual and some were auto so some wheels will have the gear change paddles.
Been speaking with this guy and he says the latest facelift S line wheel is much thicker than the TT RS and is plug and play
http://www.ebay.co.uk/itm/271443375324? ... Tags=bu=bu
I just cant see it.
I just cant see it.
I fitted the one on the right ,it's not as thick as the standard RS4 FBSW but still very nice
viewtopic.php?f=64&t=122603&p=819937#p819937
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 75 guests
