Alternator time
Re: Alternator time
Being euforic getting the bastard out, i forgot which connection to use, 1 or 2...think it was 1
Apart from that, the number on the new regulator is BR14 MO F 00M 144 146...
Mugello Blue C5 RS6 Avant
Viper Tuning ECU/TCU
Yellow Koni's
Yellow Koni's
Re: Alternator time
I would suggest 1 as 2 doesn't have the cable cutout , plus doesn't look as of it has a thread sticking out of it.
Cheers Al
Re: Alternator time
2 holds the reg pack on, 1 is the output. I changed one last week on a golf diesel looks exactly the same. The small Phillips head screws were very tight but I was changing it in situ.
Re: Alternator time
Ok thanks guys, its going in back today.
While im at it, doing an oilchange plus filter to...
Id like to do the oilchange with warm engine but its on jackstands for days now...
Yellow Koni's
Yellow Koni's
Re: Alternator time
By the way, i pushed the bush shown in the pic a bit so it Will fit more easily...
Yellow Koni's
Yellow Koni's
Re: Alternator time
Old oil out, pretty Black, smells like petrol....
Yellow Koni's
Yellow Koni's
Re: Alternator time
2 pretty bad rusted bold here, Can i just replace them with New ones or Will it be a risk regarding the gasked/start an oil leak? .....
Yellow Koni's
Yellow Koni's
Re: Alternator time
I would change them one by one. And torque the new ones up correctly.
- simonpoulton
Re: Alternator time
Mavada, how are your oil cooler pipes looking (whilst you are around that area)? Trace them back to the front cooler as mine were corroded.
Past: R56 Mini Cooper S
Re: Alternator time
Yes theyre pretty bad corroded, especially the part from flexible to connection
Yellow Koni's
Yellow Koni's
Re: Alternator time
Some more questions regarding oil.
Do i have to fill the New oil filter for 2/3 with New oil before installing it?
Do i have to replace to old gasket/ring from the engineoil drain plug?
Cheers,
Mark
Cheers,
Mark
Yellow Koni's
Yellow Koni's
Re: Alternator time
I don't prefill oil filter but I prime the engine on the starter motor. Fuse 32 29 will stop the engine starting.
I always replace the gasket and plug. At least replace the gasket.
Re: Alternator time
Motul 8100 x clean 5w40 is going in.
Yellow Koni's
Yellow Koni's
Re: Alternator time
Is it 505.01?
Re: Alternator time
Yes it is. Delivered tomorrow, on the road again soon...
Yellow Koni's
Yellow Koni's
Users browsing this forum: No registered users and 339 guests
