SOLD Genuine C7 RS6 20x9.5j et21 wheels NO TYRES
DeanoC
Re: Genuine C7 RS6 20x9.5j et21 wheels with tyres
Post by DeanoC » Tue Jan 24, 2017 7:31 pm
BMW2RS4 wrote:
Adam L wrote:
Give me a day or two and I will provide the necessary measurements for people.
Here's the steel (i.e. non-ceramic) caliper measurements for the B8 which I tend to use when buying alloys...
My current summer alloys are a similar 20 x 10 ET20 fitted 265/30 R20 though I DID experience rubbing at rear under load and during spirited cornering. This was overcome by introducing a -2 degree camber which is, apparently, the maximum negative adjustment. I haven't notice any significant uneven tyre wear as a result. They are nice & flush.
That is helpful thank you
DeanoC
Post by DeanoC » Tue Jan 24, 2017 7:44 pm
I make your setup the equivalent of running 19mm spacers compared to the standard 9.5J et 26 wheels. What is the handling and stone chip situation like?
Post by MikeFish » Tue Jan 24, 2017 7:57 pm
Standard B8 wheels are 9 inch not 9.5 Dean.
DeanoC
Post by DeanoC » Tue Jan 24, 2017 8:03 pm
Sorry yes my bad. Few too many ribenas on a school night. It is 19mm though i worked it out on 9 but wrote 9.5
BMW2RS4
Post by BMW2RS4 » Tue Jan 24, 2017 8:19 pm
My current summer alloys are a similar 20 x 10 ET20 fitted 265/30 R20 though I DID experience rubbing at rear under load and during spirited cornering. This was overcome by introducing a -2 degree camber which is, apparently, the maximum negative adjustment. I haven't notice any significant uneven tyre wear as a result. They are nice & flush.[/quote]
I make your setup the equivalent of running 19mm spacers compared to the standard 9.5J et 26 wheels. What is the handling and stone chip situation like?[/quote]
Standard tyres on the b8 are 265/30 R20 so if you consider the tyre tread footprint it sits only a further 6mm out from standard. Granted, the tyre sidewall is more stretched but it is the tyre (and not the actual wheel unless you are really slammed) that will cause rubbing and issues with stone chips and I don't find a problem. Handling, if anything, is slightly improved due to the wider track though I can't say that I notice much of a difference. On the other hand, fitting 275/30 R 20s would be a big issue. If I was on the lookout for another set of alloys, these advertised would tick all the right boxes for the B8 IMHO; they look the business :thumbs:
B8 RS4 in Daytona Grey
A1 S line Black Edition (Mrs')
Recent Past:
BMW 325i M Sport Coupe (E92), BMW Alpina D3 (E90), A4 DTM Quattro (B7), BMW M3 (E46)
DeanoC
Post by DeanoC » Tue Jan 24, 2017 10:41 pm
BMW2RS4 wrote:Standard tyres on the b8 are 265/30 R20 so if you consider the tyre tread footprint it sits only a further 6mm out from standard. Granted, the tyre sidewall is more stretched but it is the tyre (and not the actual wheel unless you are really slammed) that will cause rubbing and issues with stone chips and I don't find a problem. Handling, if anything, is slightly improved due to the wider track though I can't say that I notice much of a difference. On the other hand, fitting 275/30 R 20s would be a big issue. If I was on the lookout for another set of alloys, these advertised would tick all the right boxes for the B8 IMHO; they look the business :thumbs:
Thank you so much. That makes sense. I just drew it all to scale and yes if i keep the same tyre width it will actually only be shifted 5mm further out even though the rim grows 1mm on the inside and 11mm on the outside
Adam L
Post by Adam L » Wed Feb 01, 2017 9:40 am
Ok, excuse the late response, I have been extremely busy the last few week. I had a very short space of time yesterday to work with so my measurements may be a few mm off but these will not clear B7 calipers without spacers but appear to be fine for B8 cars. I got around 45mm clearance on the 116mm centre measurement which rapidly increased to 50 something mm for the B8's. I didn't actually make a note for the B8 as I forgot.
Regarding price I have been having a think. I will remove the tyres and will look at offers around £1500
Adam L
Post by Adam L » Thu Feb 09, 2017 12:29 pm
Bump.
Adam L
Post by Adam L » Sat Feb 18, 2017 12:18 pm
Just as a reference as I have been asked to measure the exact inner spoke clearance for B7 calipers. I made it to be between 45mm and 46mm where you need 52mm. This would ultimately mean you'd require at least a 7mm spacer to clear the calipers, or remove some of the material off the lower edges of the calipers to gain a few extra mm.
Adam L
Post by Adam L » Mon Feb 20, 2017 12:33 pm
Just realised I hadn't edited the first post with the price reduction. Looking for offers around £1450
Adam L
Re: Genuine C7 RS6 20x9.5j et21 wheels NO TYRES
Post by Adam L » Sun Feb 26, 2017 12:16 pm
Still available
Adam L
Post by Adam L » Sat Mar 04, 2017 9:00 am
Offers?
RS04YOB
Re: SOLD Genuine C7 RS6 20x9.5j et21 wheels NO TYRES
Post by RS04YOB » Mon Mar 13, 2017 9:03 am
Who bought theses want to see pic's
FaisalJ
Post by FaisalJ » Mon Mar 13, 2017 10:26 am
Not sure if it's the buyer of this particular set, but there's a guy on FB in the RS4 owners club that has them on his Avus B7
I asked him about fitment - He confirmed that he needed an 8mm spacer to clear the calipers (actually went for 10mm as he felt the clearance at 8mm was tight). At least it means Adam and my measurements are right!
2007 RS4 B7 Avant
RS04YOB
Post by RS04YOB » Mon Mar 13, 2017 10:45 am
Do you have link to the page
