iPhone Compatibility
timthetooth
Hello, I am a relatively new owner of a lovely blue RS6 C6 Avant. Although I am revelling in the power, build quality, and style, I am frustrated that I cannot play music from my iPhone 6 through the cable provided. I have updated the software to the 5570 version, but that did not help.
An old iPod works fine, using the old Apple connector cable.
Is there any fix, or do I just have to accept it?
Tim
Tim
You need to get a lightning plug adapter to go into the MMI system in the glove box and then a separate cable into the phone itself. I use this one and it works well:
https://www.amazon.co.uk/CableJive-dock ... =Cablejive
Current:
Former:
2016 R8 V10 Plus.
2019 E63s AMG 4Matic Estate.
2017 BMW M3 Competition Pack.
2015 A45 AMG.Overrated POS.
2016 C7 RS6 Panther black.
2006 BMW Z4M Roadster.
2004 Alpina Roadster.
1994 E34 M5 Saloon
Former:
2016 R8 V10 Plus.
1994 E34 M5 Saloon
Re: iPhone Compatibility
Or get a Bluetooth adaptor for the mmi then you can play off any Bluetooth device. It's not the cheapest but saves you putting your phone in the glove box.
c6 rs6 avant- mrc stage 2 -current
bmw e61 m5 saloon
s3 8p stage 2
vw bora tdi hybrid turbo
bmw e61 m5 saloon
s3 8p stage 2
I use a magnetic holder to fix my phone to one of the air vents for easy access.
Current:
Former:
2016 R8 V10 Plus.
1994 E34 M5 Saloon
Former:
2016 R8 V10 Plus.
1994 E34 M5 Saloon
timthetooth
Thanks guys, I think I will buy the bluetooth adapter.
Studiowise
- 1st Gear
Let me know which BT one you get that works, I've got the lightning connector which works well with my iphone7+ but my daughters would agree stream their stuff from the back seats. Thx
____________________________________________________
RS6 C6 MTM Map Engine & Gearbox STAGE2
My lightning adaptor seemed to stop working in recent software updates for some reason.
The Bluetooth option sounds perfect (avoiding the whole phone in glove box scenario)
Would someone please share a link of an example online of this exact 'bluetooth' option for 2G. Thanks in advance.
Adam
RS6 Wagon - C6
RS6 Wagon - C6
They are called tune 2 air just google it they are on amazon or eBay , some go direct into the ami unit or some go onto the 20pin apple cable but dead easy and you phone can connect to its original bluetooth and this at the same time
bmw e61 m5 saloon
s3 8p stage 2
bmw e61 m5 saloon
s3 8p stage 2
I have tune2air module as well, Bluetooth streaming works perfectly...!
Audi RS6 C6 Exclusive black-brown
Nappa leather and Ceramic
timthetooth
An update, I bought a ViseeO Tune2Air WMA3000A, from eBay, £60 (cheap as a working returned item). It works well with music stored on my iPhone 6s, the MMI display showing songs etc. Using Spotify it streams the music, but you have to use the phone to cue the music, as the interface does not allow remote control of the phone from the car controls.
Hope that helps.
Tim
Hope that helps.
Tim
I have a Huawei P9,
and for instance the volume is controlled by the mmi , when I mute the mmi or If switch to the radio, the tel stops playing
I purchased one of these VMA3000A tune2air and whilst the car seems to recognise it is attached (the device flashes blue as per instructions, states initialising device. please wait) it then states on the MMI
"Cannot read from connected device"
Any thoughts, am I missing something here?
Thanks in advance.
Thanks in advance.
Adam
RS6 Wagon - C6
RS6 Wagon - C6
THatsas your t connected to it , you need to pair with it and it will take about 30 seconds or so to start playing must after start up.
You will be looking for a Bluetooth called tune2air I think you will then be able to have bluetooth connected to mmi and the tune2air at the same time. Occasionally Iv had an issue so just unplug and plug it back in and it works
bmw e61 m5 saloon
s3 8p stage 2
bmw e61 m5 saloon
s3 8p stage 2
