Water in boot ???
skirs6
Water in boot ???
Post by skirs6 » Sun Jan 22, 2017 5:51 pm
The joys of buying used !!!!! First day I've had since collecting last Saturday to have a good look round. By chance my sons car wouldn't start so I got some jump leads reversed mine up to his removed the plastics boot liner thing only to find the carpet soaked the tool kit full of water and the battery covered in condensation from the water its sitting in.
Any others had this ??? No sign of any water above on the carpet so not sure where it's come from?
Back to Audi me thinks
Needmorespace
Re: Water in boot ???
Post by Needmorespace » Sun Jan 22, 2017 6:00 pm
Not seen that in mine. Maybe previous owner spilled something or Audi jet washed the boot as part of their hand over prep...the battery cables go out through the boot floor so maybe a loose grommet
wildbore
Post by wildbore » Mon Jan 23, 2017 9:56 am
When I see this, my first thought is always to the rear light clusters. Have they ever been changed? Have they been replaced because of a fault?
skirs6
Post by skirs6 » Mon Jan 23, 2017 8:40 pm
wildbore wrote:When I see this, my first thought is always to the rear light clusters. Have they ever been changed? Have they been replaced because of a fault?
I don't know the answer to that. I took it back to Audi this evening. It's booked in next week to have all the rear stripped out dried/replaced. Then water test. When we lifted more of the carpet in the boot it was actually flooded right across about an inch deep under the battery. They were just about to close when I got there so I said I would start the process to at least get it dry.
It took me over an hour tonight to suck out most of the water with a large syringe with tube attached.
It's very strange as there is no musty smell in the boot the water is clear with no smell but did go slightly frothy when sucked up.
The way the tool tray and jack tray have been filled would suggest it could only have come from above yet everything above is bone dry.
It would appear to be a very recent ingress of water not over a period of time. Baffled !!!!!
RS6chris!
Post by RS6chris! » Mon Jan 23, 2017 9:13 pm
Does the car not steam up at all?
If the water had been there for a while you'd expect steaming up and a
Foists smell surely?
RS6 C8 carbon black(merlin)
Panamera Turbo S e hybrid
RS6 C8 launch edition
R8 V10 plus
C7 RS6 PE dynamic pack plus
C7 RS6
Porsche Panamera Turbo
C6 RS6 AVANT
RS4 B7
Golf R32 mk 5
BMW M3 E46
Golf R32 mk 5
Golf GTI mk 5
VW Passat 130d 4 motion
VW bora 150pd
Ford Mondeo Ghia X V6
Ford Focus zetec
Rover 214!!
skirs6
Post by skirs6 » Mon Jan 23, 2017 10:14 pm
Chris no it doesn't but it's pretty cold at the moment which may account for the lack of steaming up. It's a bit bizarre. I've got a day off work Wednesday so going to have a good look and do some water tests myself as Audi are fully booked until next week.
Eddie555
Post by Eddie555 » Mon Jan 23, 2017 10:51 pm
Do you park on an incline with the rear pointing down?? My brother had a problem like this,although it was a BMW X5, and it was down to the panoramic roof drain tubes which had come loose and water ran down the rear quarters.
Current ride’s
Previous rides
skirs6
Post by skirs6 » Mon Jan 23, 2017 11:09 pm
Eddie555 wrote:Do you park on an incline with the rear pointing down?? My brother had a problem like this,although it was a BMW X5, and it was down to the panoramic roof drain tubes which had come loose and water ran down the rear quarters.
No mate at work it's in multi storey and home under car port.
daytonamart
Post by daytonamart » Tue Jan 24, 2017 9:27 am
Any chance this was down to over zealous cleaning with the pressure washer?
Gone B7 RS4 Sprint Blue Avant
Gone B7 A4 Reflex Silver
skirs6
Post by skirs6 » Tue Jan 24, 2017 9:12 pm
daytonamart wrote:Any chance this was down to over zealous cleaning with the pressure washer?
Surely you can't get that much water in that area by just jet washing ??? Well maybe with the boot open ( laughing faces. )
skirs6
Post by skirs6 » Tue Jan 31, 2017 9:47 pm
Seem to have found the answer. I spoke to the previous owner today. The car had the ROS wing replaced a while back and it appears the light cluster and rubber gaskets haven't been fitted that well. Confirmed after water test today at Audi. Fingers crossed will all be sorted tomorrow and I can finally enjoy the car
Post by MikeFish » Tue Jan 31, 2017 9:49 pm
Why did they replace the rear quarter panel? That's a proper cut out and weld back in job isn't it?
doodlebug
Post by doodlebug » Tue Jan 31, 2017 9:50 pm
Aye, that's had a shunt surely.
skirs6
Post by skirs6 » Tue Jan 31, 2017 9:53 pm
From the previous owner. He managed to reverse it into a skip on his drive while rushing to get to work. It was done through an insurance approved repairer.
He even said he didn't think it needed a complete new wing but that's what they did. Probably another insurance approved repairer taking the p##s
Post by MikeFish » Tue Jan 31, 2017 9:55 pm
Did you know this before you bought it or did you only just find it out?
Users browsing this forum: No registered users and 44 guests
