Electrical problem
gedRS
Electrical problem
Post by gedRS » Sat Jan 21, 2017 11:39 am
Got problem and i need your advice.
Lost all electrics yesterday, a gradual decline over a few miles, battery light on, lost every electrical thing in the car, then into limp mode eventually ending up on the side of the road....I did have an issue with the big fuse a while back, the 200amp one, it was under water once drained it was ok so never looked again. Question is do you think thats the issue or does it point towards alternator ? If it is the alternator which i suspect how big a job is it by RS6 standards ? After 11 years of ownership i should know the answer to that question already.
ahoooga
Re: Electrical problem
Post by ahoooga » Sat Jan 21, 2017 12:13 pm
Ever had a new battery ? Just had a Polo's electrics die over night, no symptoms the day before, assumed a direct drain somewhere, put new battery on, no issues since
mavada
Post by mavada » Sat Jan 21, 2017 12:13 pm
Good luck. :D
www-rs6-com.pdf
(893.72 KiB) Downloaded 52 times
Mugello Blue C5 RS6 Avant
Viper Tuning ECU/TCU
Yellow Koni's
TechNick
Post by TechNick » Sat Jan 21, 2017 12:31 pm
What did you observe from the dash battery guage, whilst the symptoms were occurring? Solid 14V or steady decline?
gedRS
Post by gedRS » Sat Jan 21, 2017 12:45 pm
To be honest i didn't really notice any decline but we put another fully charged battery on to get me home and the battery light was still all the way home on and it did decline a little on the 20min journey, not sure if thats a clue but i guess it points to alternator...?
gedRS
Post by gedRS » Sat Jan 21, 2017 12:47 pm
ahoooga wrote:Ever had a new battery ? Just had a Polo's electrics die over night, no symptoms the day before, assumed a direct drain somewhere, put new battery on, no issues since
No its had the same battery since new...i will get it checked
cheers
Ajc
Post by Ajc » Sat Jan 21, 2017 2:18 pm
Check your getting a good charging voltage with the car running using a multimeter in the battery . If your only getting 12v or less I would suspect its the alt at fault though check the fuse under the header tank and make sure the connections are clean and you have good connections and voltage flowing though it .
Cheers Al
Post by bam_bam » Sat Jan 21, 2017 4:44 pm
Alternator gone or main fuse corrosion. .
Mr Footlong
Post by Mr Footlong » Sun Jan 22, 2017 9:07 am
bam_bam wrote:Alternator gone or main fuse corrosion. .
^This^
Current:
Gone:
gedRS
Post by gedRS » Fri Jan 27, 2017 4:53 pm
Well it was the alternator voltage regulator and its being fixed as we speak.....
Users browsing this forum: bilko1, philS2 and 161 guests
