Headlamp Bulbs
JimRS6
Headlamp Bulbs
Post by JimRS6 » Thu Jan 12, 2017 9:40 pm
Guys,
Which bulbs do I need to replace the xenons? I've got one dipped failing - it's taking ages to come on, and repeated main beam on/off cycles(Pass side)
I popped into Halfrauds and they wanted silly money, and couldn't distinguish the RS6 between an A6 on their system.
Mugello Blue 2003 Audi RS6 Avant
Flame Red 1998 Vauxhall Astra GSi 4x4
Taunton, Somerset
Mɐʇʇ
Re: Headlamp Bulbs
Post by Mɐʇʇ » Thu Jan 12, 2017 11:04 pm
Euro car parts list some osram ones for 40 quid.
I'd also replace both at the same time - the colour of them changes over time so it'll probably look odd if you only replace one.
They've got a sale on...although their sales seem to be a bit like sofa wholesalers - but that brings the price down to 30 quid each.
simonpoulton
Re: Headlamp Bulbs
Post by simonpoulton » Fri Jan 13, 2017 9:19 am
Is it definitely the bulb? They have the high voltage ballasts can also fail so might be worth swapping the bulbs from left to right etc and seeing if the problem persists.
Past: R56 Mini Cooper S
JimRS6
Re: Headlamp Bulbs
Post by JimRS6 » Fri Jan 13, 2017 11:11 am
It's still currently working -just
But cheers I will check the ballasts, can't imagine they are cheap to replace.
I have got one bulb that isn't as 'blue' as the other, although it's the one that is coming on fine.
Will get the bonnet open and have a look later.
Thanks Guys
Taunton, Somerset
simonpoulton
Re: Headlamp Bulbs
Post by simonpoulton » Fri Jan 13, 2017 11:32 am
You probably already know this but they work on really high voltage. Best make sure they are off first before fiddling!
JimRS6
Re: Headlamp Bulbs
Post by JimRS6 » Fri Jan 20, 2017 9:57 pm
Update: tried the drivers side bulb in the place of the one that isn't working properly, and it worked, so its bulb and not ballast
Taunton, Somerset
nene
Re: Headlamp Bulbs
Post by nene » Sat Jan 21, 2017 4:10 am
I replaced mine with 5400K Osram Xenarc. They were slightly better white than the stock 4300K. They have been great and working for many years now. Hope I did not jinx myself.
Users browsing this forum: Quinten and 66 guests
