New exhaust
bigbaz1974
- 1st Gear
New exhaust
Thinking of a new exhaust guys, for example a miltek. My question is does the car need a remap when a different exhaust is fitted or can it go straight on with no changes to the ECU. thanks in advance
Re: New exhaust
My understanding is if you don't change the cats then no ecu tweek is needed just bolt on an go
2018 B9 RS4 Navarra Blue
2013 B8 RS4 Sepang Blue
2007 B7 RS4 Avant Sprint Blue
2001 B5 RS4 Nogaro Blue
1993 B4 S2 Avant laser Red
bigbaz1974
- 1st Gear
Re: New exhaust
Thanks mate, I take it when you buy a system and it says cat-back, you keep the original cats on the car then replace the rest of the exhaust?
Re: New exhaust
That's my understanding of cat back system
the question really is which to go for Miltek HMS custom im sure some one with a after market one will let you know how there experience has been
Re: New exhaust
Yes you won't change the cats on a B8 unless you get new manifolds and take the engine out.
Most will either connect to the downpipes or after the front silencers.
You won't need an ecu tweak but it may help. Big revvy, powerful NA V8's are very sensitive to exhaust design.
Depending on what you are after you may get away with chopping out the front or middle silencers for a few hundred quid
bigbaz1974
- 1st Gear
Re: New exhaust
Wanting an exhaust for improved sound more than anything
- Surrey Sam
Re: New exhaust
Removing the centre resonator would probably be your best bet then, if you just want to make it louder for little cost.
Re: New exhaust
Loads on here re exhausts search Boffs exhaust thread for me capristo all day long however weak pound to euro may have made prices soar
ant@apautomotive
- Trader (Expired)
Re: New exhaust
The capristo is an excellent choice, but not the most economical on the wallet.
We have done a couple of X pipe exhausts on these. This Mod retains the full switching of the valves with an increase in volume without being overly loud.
The thing with the RS4 is that a lot of sound is muted due to cabin insulation, and perception of sound and volume is different in the car as it is to outside of the car.
We have a brief video clip on our Facebook page if you would like to get an idea of X pipe sound. www.facebook.com/apautomotivetelford
Ant
Ant
AP Automotive - Parts, Servicing, Performance.
T: 01952 794024
E: info@apautomotive.com
W: www.apautomotive.com
T: 01952 794024
bigbaz1974
- 1st Gear
Re: New exhaust
Ant,
When you say x pipe does that just mean putting an X section in the middle of the original exhaust thus removing the silencer parts in the centre section????? Does this involve cutting the exhaust and welding in the X section????
Thanks Barry
Thanks Barry
Re: New exhaust
You can see a custom x in place of the middle silencer below:bigbaz1974 wrote:Ant,
Thanks Barry
The off the shelf jobbies like supersprint normally clamp on where the original join is behind the front silencers and a new clamp before the rear mufflers.
bigbaz1974
- 1st Gear
Re: New exhaust
Thanks for that, can you buy the one in the photos off the shelf aswell or has this been specially made. I see the pics of the one ant mentioned just removes the centre muffler. Your pic the front mufflers are removed also
Re: New exhaust
You sure can. Supersprint do one in resonated or unresonated:bigbaz1974 wrote:Thanks for that, can you buy the one in the photos off the shelf aswell or has this been specially made. I see the pics of the one ant mentioned just removes the centre muffler. Your pic the front mufflers are removed also
Christurbo
- 1st Gear
Re: New exhaust
Just found this... is this your car Deano? Looks like you have straight pipes not X Pipe?
Or is the X towards the rear (can't tell from photo)...
Users browsing this forum: No registered users and 364 guests
