Adjusting rear bilstein coilovers
Rw@@dy
Re: Adjusting rear bilstein coilovers
Post by Rw@@dy » Mon Jan 02, 2017 8:54 am
Starry wrote:I'm looking to install my b14's in the next week or so. Judging by this thread the rears are a pita so I'm hoping to get them set to the right hight before fitting them.
I want to run it pretty low, does anyone know where i should be looking to set them? Also, how much will they settle once fitted?
Mine are set right at the bottom and have Been on for 2 weeks
Starry
Post by Starry » Mon Jan 02, 2017 10:30 am
Thanks for that, are those 20's? Any rubbing? Any spacers?
I'll be running the 20" S5 wheels which are very close to the oem 19" in size and poke.
2006 RS4
Phantom black
MRC Stage 2, Milltek non res, pre cat delete,
Rw@@dy
Post by Rw@@dy » Mon Jan 02, 2017 12:25 pm
Yes mate they are 20" s5 wheels, I was running 10mm spacers on the rear and wore part of the tyre away on the side wall! Swapped to 8mm all round and no problems so far
Starry
Post by Starry » Mon Jan 02, 2017 9:05 pm
Rw@@dy wrote:Yes mate they are 20" s5 wheels, I was running 10mm spacers on the rear and wore part of the tyre away on the side wall! Swapped to 8mm all round and no problems so far
Thanks for the info, are the front and rear both at they're lowest, looks like we will have a similar set up soon.. :big blink:
2006 RS4
Phantom black
Rw@@dy
Post by Rw@@dy » Mon Jan 02, 2017 9:17 pm
Not sure on the front, don't think it is
Starry
Post by Starry » Mon Jan 02, 2017 9:43 pm
Are the fronts easier to adjust on the car than the rears?
2006 RS4
Phantom black
Rw@@dy
Post by Rw@@dy » Mon Jan 02, 2017 9:45 pm
Yeah I believe so, rears supposedly a right pain! There's another thread about it
docurley
Post by docurley » Mon Jan 02, 2017 10:02 pm
Set it higher than you think because it will drop lower after a week trust me.
BenHol
Post by BenHol » Mon Jan 02, 2017 10:29 pm
Starry wrote:Are the fronts easier to adjust on the car than the rears?
Front is easy. Just drop the wheels and put full on full lock
RS4 B7 - Phantom Black, 20in RS6 C7 alloys, Joey mod, detango, led drl, black optics, Bilstein b16, Michelin ps4s, centre res delete, black tips, 8mm spacers, vx lenses, RS embossed xenon, Carbon splitter, 034 ARB.
Neilb76
Post by Neilb76 » Wed Dec 27, 2017 9:59 pm
Dragging a old post up but thas the search engine for ya.
I tried to adjust my rears i could turn it no problem with force but the whole shim spun as well so i go no wear. Has anybody figured out how to stop this happening
rs user
Post by rs user » Thu Dec 28, 2017 10:56 am
drill hole/holes if needed in the threaded part that the adjuster spin on[at the end of it or bottom -but not where the adjuster will run]
insert rod/appropriate screwdriver to hold threaded part and adjust ring quarter turns at a time-its still a pita and threads need to be clean and lubed up-its easier the lower you go-but i run mine at the upper height range so more preload/harder to turn
rickster147
Post by rickster147 » Thu Dec 28, 2017 1:22 pm
Yep I drilled holes too to hold it and stop it spinning round fronts are easy
Rears patience and scabby knuckles!!!
Rs4 b7 In avus silver with b14 Bilstein coilovers, centre resonator delete with x pipe and piggie cats gutted
Headlights detangoed trups led kit drl reverse and numberplate kit
Previous audi
rs6 c5 - mrc stage 2 remap-itg filters-forge dumpers-center decat with miltek kw coilovers- h and r
I call her the growler lol
Neilb76
Post by Neilb76 » Thu Dec 28, 2017 1:39 pm
Am i right in saying wind down the ring to raise the car as mine needs raising about 15mm as it has settled now
Jon_J
Post by Jon_J » Sat Dec 30, 2017 6:59 pm
I got bored trying to adjust it, took it to a garage, they dropped the subframe and did it easy. Couple of hours labour, no smashed knuckles.
RS4 B7 Sprint Blue
- Titanium Pack
- Black Optics
- B16's
- RNSE2 with AMI
- Reverse Camera
- Full Stereo install
S5 8T Cab White
A5 Cab 3.0 TDI Phantom Black
