Insane break noise
danilobandeira
- 1st Gear
Insane break noise
I dont know what yo do anymore. I trade 3 times my front pad brakes (some with 1k miles) because of the noise. A sharp noise... you can hear 2 blocks far
What can i do? The dealer does not give me a good answer for that.
I used this pad brake number: 4H0698151C
Audi rs6 c7 2014
9k miles
21 inch
Ceramic brakes
https://vimeo.com/197630603
https://vimeo.com/197630664
Enviado do meu iPhone usando Tapatalk
Audi rs6 c7 2014
9k miles
21 inch
Ceramic brakes
Re: Insane break noise
You sure they haven't fitted pads For steel discs instead of ceramic pads??
RS6 C8 carbon black(merlin)
Panamera Turbo S e hybrid
RS6 C8 launch edition
R8 V10 plus
C7 RS6 PE dynamic pack plus
C7 RS6
Porsche Panamera Turbo
C6 RS6 AVANT
RS4 B7
Golf R32 mk 5
BMW M3 E46
Golf R32 mk 5
Golf GTI mk 5
VW Passat 130d 4 motion
VW bora 150pd
Ford Mondeo Ghia X V6
Ford Focus zetec
Rover 214!!
R8 V10 plus
C7 RS6
C6 RS6 AVANT
RS4 B7
Golf R32 mk 5
BMW M3 E46
Golf R32 mk 5
Golf GTI mk 5
VW bora 150pd
Ford Focus zetec
Rover 214!!
The part No is correct for Ceramic disks
Do you have any to swap with my steel brakes they are totally silent
Volvo XC90
C7 - RS6
C6 - RS6
B5 - RS4
C7 - RS6
C6 - RS6
B5 - RS4
danilobandeira
- 1st Gear
I dont know what to do
- feeltheburn
That sound would drive me crazy!
Have you tried bedding them in a way similar to this procedure:
http://www.pistonheads.com/gassing/topic.asp?t=1552095
I know from our karting days [different but still same principal] that for the specialist pads that we used [for steel] it was critical to follow the bedding in procedure or we got excessive glazing which resulted in both poor performance and increased noise. We used a cheap IR type thermometer [eBay] to check our temperatures were around what our procedure said [accuracy is ok if you measure over a short distance]. Might be too late to try the bedding in procedure but must be worth a try to get rid of that noise!
[note:I have steel brakes so just sharing an opinion]
RS6 C7 (2014), Daytona Pearl, 21" Titanium, On Air, LEDs, Sports Exhaust, Dynamic Steering, Red Calipers, ACC, Top View, Connect, Tints, Rear Side Airbags, Rear heated seats; MP4S
danilobandeira
- 1st Gear
I did... in the second time that i trade, i went to a track day in the next day... hard braking and accel... but the noise doesnt stop.
With these one now, i did some hard braking, the noise "disapear" for the next 2 standart braking and at the third standart braking, the noise appears
I don't profess to be an expert at any level with brakes....however I think discs and pads have something on surface, whether that's wear and tear or a baked on film or similar causing noise once pads are applied .
Is it all four or just fronts??....both fronts??
R8 V10 plus
C7 RS6
C6 RS6 AVANT
RS4 B7
Golf R32 mk 5
BMW M3 E46
Golf R32 mk 5
Golf GTI mk 5
VW bora 150pd
Ford Focus zetec
Rover 214!!
R8 V10 plus
C7 RS6
C6 RS6 AVANT
RS4 B7
Golf R32 mk 5
BMW M3 E46
Golf R32 mk 5
Golf GTI mk 5
VW bora 150pd
Ford Focus zetec
Rover 214!!
danilobandeira
- 1st Gear
Both fronts... sometimes the right, sometimes the left
That would drive me crazy, it sounds like they need a good stomping on from high speed to clear off any surface contamination.
Have you thought about removing the ceramics completely and replacing with the normal RS6 steel setup? Sell on the Cermaics, unless you regularly track the car, they are really just for the aesthetic appeal. Would save you a lot of headaches (literally)
MY16 Audi RS6
Il give you £100 for The full ceramic set up?...
R8 V10 plus
C7 RS6
C6 RS6 AVANT
RS4 B7
Golf R32 mk 5
BMW M3 E46
Golf R32 mk 5
Golf GTI mk 5
VW bora 150pd
Ford Focus zetec
Rover 214!!
R8 V10 plus
C7 RS6
C6 RS6 AVANT
RS4 B7
Golf R32 mk 5
BMW M3 E46
Golf R32 mk 5
Golf GTI mk 5
VW bora 150pd
Ford Focus zetec
Rover 214!!
- feeltheburn
See here for some info regarding glazing/deglazing:
http://frixa.org/technical
Bedding-in is much more than just giving them a good "roasting". Might be worth taking the pads out and seeing if they are shiny and pitted like in the article- I am sure there are many more sites that will have even more information/guidance regarding glazing.
Ceramic or steel- glazing can be an issue and as I recall it sounds [on steel] very much like what you are experiencing.
