advice for rs6 v10
huntersmob
Re: advice for rs6 v10
I was thinking of look at this one
http://www.autotrader.co.uk/classified/ ... 501&page=2
and this one
any of them know ?
and this one
any of them know ?
First has the benefit of the Milltek if you're thinking of upgrading the exhaust but you need to find out if the oil seals have been done and what state the coolant lines are in. The second one has a nice spec bar the aluminium trim (in my humble opinion of course).
Daytona Grey C6 RS6 Avant
Ebony Black C5 RS6 Plus - Gone
huntersmob
yes I like the blue also
so are the oil seals, coolant pipes and the suspension pipes the main problems
Oil seals and Coolant pipes are the main issues but the car are getting to an age now where rust/corrosion etc are starting to cause issues. The DRC struts are extremely reliable, it's the flexible hoses from the car to the strut (which is also the connection point when re-gassing) which are starting to fail due to corrosion, but this is in very limited numbers to be fair.
Lots and lots of info on here about the seals and coolant lines etc
huntersmob
so what are the average costs for
1 the coolant pipes
2 the oil pump seal
3 the drc recharge etc
1 the coolant pipes
2 the oil pump seal
1 & 2 £2300 labour pipes are around £300
Volvo XC90
C7 - RS6
C6 - RS6
B5 - RS4
C7 - RS6
C6 - RS6
B5 - RS4
huntersmob
is that 2300 for both 1 and 2 or each ?
If you did together I reckon you could get both jobs done within that labour charge - if you did separately same cost
Volvo XC90
C7 - RS6
C6 - RS6
B5 - RS4
C7 - RS6
C6 - RS6
B5 - RS4
huntersmob
good to know if one has not been done
DRC regass at Unit20 is under £200 IIRC (have a figure of £175 in my head but can't be 100% sure thats right).
The one at asm is lighy on spec, and is leaking from the rear seal
TTS Charged RS4 plus all the goodies
huntersmob
cheers is that the black one, the dealer does not do score very well alsoRegy53 wrote:The one at asm is lighy on spec, and is leaking from the rear seal
Put up a wanted ad in classifieds and hopefully a forum owner may contact re selling their car
Volvo XC90
C7 - RS6
C6 - RS6
B5 - RS4
C7 - RS6
C6 - RS6
B5 - RS4
huntersmob
posted cheersrtd wrote:Put up a wanted ad in classifieds and hopefully a forum owner may contact re selling their car
Users browsing this forum: Bing [Bot] and 44 guests
