the slave cylinder is the master is under the dash and its plasticirn_bru_ce wrote:So the original audi master cylinder is made of plastic? Outrageous
Clutch issue
boombastik
Re: Clutch issue
RS4 B7 Saloon Milltek Cat back, CAF with piper cross panel, Wrapped optics black, Satin black wheels, TRUPS LED front DRL's & sides, goodridge braided hoses, H&R 10/15mm spares front/rear
Bilstien B16 coilovers with H&R anti roll bars
MRC stage 2 deflapped, precat gutted 439ps 481nm torque
1/4 mile time 12.884sec
My clutch replacement write up can be found here viewtopic.php?f=35&t=116929&start=15
boombastik
Re: Clutch issue
Update on the car
Up at the garage for 730 this morning got it on the lift so I have replaced the clutch bearing slave cylinder clutch lever & replaced the rubber pipe for a braided pipe.
All back together bleed the system and everything is working fine
Having inspected all the parts I replaced I can't find any faults with any of them...
Any way I now have gearbox removal and replacement to a fine art now haha.
Re: Clutch issue
Good to hear.
Re: Clutch issue
You can come and do mine then when it needs doing lol
Seattle-squash
Re: Clutch issue
Nicely done!
did the USP line work for the right hand drive?
boombastik
Re: Clutch issue
Unfortunately not it was about 8" too short. So getting sent back today.Seattle-squash wrote:Nicely done!did the USP line work for the right hand drive?
Seattle-squash
Re: Clutch issue
You got one fabricated instead or you picked up a right hand drive specific one?
- markshepps
- 1st Gear
Re: Clutch issue
Arse... I've just had one of these delivered. I thought I'd seen others on the forum using this setup?boombastik wrote:Unfortunately not it was about 8" too short. So getting sent back today.Seattle-squash wrote:Nicely done!did the USP line work for the right hand drive?
boombastik
Re: Clutch issue
You will be able to use it but you will need a braided pipe made to suit and long enough to attach from the slave to the metal pipe just coming down from the firewall I just didn't have time to get one mademarkshepps wrote:Arse... I've just had one of these delivered. I thought I'd seen others on the forum using this setup?boombastik wrote:Unfortunately not it was about 8" too short. So getting sent back today.Seattle-squash wrote:Nicely done!did the USP line work for the right hand drive?
- markshepps
- 1st Gear
Re: Clutch issue
Arse... I've just had one of these delivered. I thought I'd seen others on the forum using this setup?[/quote]
You will be able to use it but you will need a braided pipe made to suit and long enough to attach from the slave to the metal pipe just coming down from the firewall I just didn't have time to get one made[/quote]
Just ordered Robnic's braided pipe instead... Too much faffing about already... My flywheel has been stuck in customs for over a week and no sign of it getting to Parcel Force anytime soon... T'is the season I guess! Rob's team were great at getting the pipe sorted... Friday before Christmas... Had it made & shipped before lunch time!
- Mr Footlong
Re: Clutch issue
If you don't mind saying, can you go in to more detail about what exactly you had rebuilt/replaced on box, how much it cost and how it feels now? Thanks.mikep99 wrote:Mines in at the moment for a gearbox rebuild / clutch and uprated pipe. Can't wait to get it back.
3rd gear synchro the main reason it's being done....
Current:
Gone:
Gone:
Re: Clutch issue
The 3rd gear synchro failed leading to crunching going into 3rd.Mr Footlong wrote:If you don't mind saying, can you go in to more detail about what exactly you had rebuilt/replaced on box, how much it cost and how it feels now? Thanks.mikep99 wrote:Mines in at the moment for a gearbox rebuild / clutch and uprated pipe. Can't wait to get it back.
I've had the gearbox rebuilt - the only thing they found that needed replacing was the 3rd gear synchro, everything else was ok.
When it was put back in the car I had the clutch, master cylinder and uprated return pipe fitted.
About £1600 all in and it feels fine now.
Had it done just before Christmas and done about 600 miles.
HTH
Mike
- Mr Footlong
Re: Clutch issue
Not bad, was that with an OE clutch or LUK? Boggo master cylinder and Robnic clutch i assume from your earlier post. Who dropped/rebuilt/refitted the box please? Thanks.
Current:
Gone:
Gone:
Re: Clutch issue
yep, luk clutch, standard master & Robnic pipe.
I used http://www.qrsport.com
They use a gearbox specialist once the box has been dropped etc...
ta
Mike
ta
Mike
- Mr Footlong
Re: Clutch issue
Thanks, useful info to have on here for others.
Current:
Gone:
Gone:
Users browsing this forum: No registered users and 236 guests
