Headlight
Headlight
Started car this morning and main os dipped main bulb out
Now is it a bumper off job or can you do it without removal of the bumper?
I'll change them both while I'm at it to 6000k
If I have to take bumper off I might take the orange indicator cover out of the head light and put some chrome bulbs in its place
Are the main bulbs d1s?
What type of bulb are the front indicators also?
Any one have a bumper removal guide?
Thanks in advance
Thanks in advance
Rs4 b7 In avus silver with b14 Bilstein coilovers, centre resonator delete with x pipe and piggie cats gutted
Headlights detangoed trups led kit drl reverse and numberplate kit
Previous audi
rs6 c5 - mrc stage 2 remap-itg filters-forge dumpers-center decat with miltek kw coilovers- h and r
I call her the growler lol
Previous audi
Re: Headlight
I think it is a bumper off job but let someone else confirm that, I know a couple of the guys have fitted new bulbs recently. Maybe hit Trups up on here, he'll be able to answer and help you with any globes you need.
Here is a decent guide I've used a few times - http://www.audizine.com/forum/showthrea ... er-Removal
Make sure you've got all the tools listed including the long torx driver.
Re: Headlight
Yes it's a bumper off job...
I have done it probably 30+ times on both my b7 and it takes me 10-15 min but man you should hear me swear at Audi every time I do this....
Anyhow, removing is actually easier than installing.
1) jack the car (taking the wheels makes it slightly easier but not essential)
2) remove all holding pins/bolts underneath 5/7 of them I think.
3) remove 3 bolts at top of the grill
And loosen 2 bolts at the adjusters.
4) remove some bolts for the lining of each wheel enough for you to reach inside the arch with very long extension and 10mm socket. I use 10inch flex to witch I attach 10mm socket and also 5 inch solid extension on 1/8 ratchet. Shine a torch inside the arch and you can see 2 bolts holding the bumper. Remove!
5) now unclip both sides of bumper (just pull gently each side and you will see what I mean.)
6) now Remove bumper. But be careful it's heavier than you think. Also don't forget about wires ant washer pipes.
Install is the reversal. But a lot more amusing
Enjoy!
Enjoy!
RS4 B7 aka Vinnie
RS4 B7 aka Vinnie
Re: Headlight
Great will look forward to it not!
Wish me look will tackle it after chrimbo
Previous audi
Previous audi
Re: Headlight
I have changed the drivers side bulb, without removing the bumper. It's roughly a 20 mins job. The hardest part is manoeuvering the airbox out, once that's done it's seconds after that.
Passenger side can be done too I've read without bumper removal, it's a case of removing all the pipework that's in the way(power steering and housing).
Daytona Grey, Bilstein Coilovers, Pre-cat delete, Centre resonator delete, IM flaps/vains delete, Interior/Exterior LED kit, CAI, Black Optics.
Other car: Bread Van
Re: Headlight
I've read that too but think I'll go the bumper route as have changed my drl to trups lights and only just managed to do those but my hands was bleeding from the tight access had to undo the drivers side drl with a screw driver and a hammer as I have biggish hands
Previous audi
Previous audi
Re: Headlight
- John Johnson
- 5th Gear
Re: Headlight
How hard was it ? I'm thinking of swapping mine as they are the original ones and not great compared to stuff in my new vehicles
Current toys in the garage
B7 avant in Daytona with ceramics and a few other goodies and lowwwww miles
Ur quattro. lago Blue
Ur quattro. Mars red
Rs1600i
Transit custom sportvan
http://youtu.be/FWBUl7oT9sA
Rs1600i
Re: Headlight
I removed the bumper , as said above its harder to get back on than off .
Why it was off I changed all the bulbs.
Hate the job to be honest and dred a bulb going lol
Re: Headlight
It's not too bad if you have the right tools just take your time I fitted bumper back better than it was before with no gaps
Previous audi
Previous audi
