My mate's RS6 is playing up. He was driving down the road, went to put the pedal to the metal, and the revs dropped off and the engine stalled.. it worked out the one of the fuses that run the engine had blown.
He took it to the dealers who hooked it up to the diagnosis.. no fault codes.. so they replace the fuse...
but it's happened again.. same fuse gone..
again, nothing on the diagnosis..
anyone got any ideas what could be causing this?.. the dealer has been around the loom but can't see anything wrong?
Problem with RS6?
Problem with RS6?
Now waiting (again!): Misano RS4 B7 Saloon.
RE: Problem with RS6?
pipework on turbo's???
mine came loose and lost all power, didnt stall but hesitated and did a bit of kangarooing...if that makes sense!!
Which fuse has blown - what exactly does it feed? If neccessary, read from the owners manual. It looks like it's the ECU fuse, but you would expect a power loss fault code if the ECU is reset - strange? Does it only happen under certain conditions i.e. when the engines cold? when it's wet?
Cheers guys,
i will try and find out more..
Users browsing this forum: rs4wagon and 87 guests
