Clutch issue
boombastik
Re: Clutch issue
In the USA
I'm hoping to get all parts I need early next week and have the car back together at the weekend
RS4 B7 Saloon Milltek Cat back, CAF with piper cross panel, Wrapped optics black, Satin black wheels, TRUPS LED front DRL's & sides, goodridge braided hoses, H&R 10/15mm spares front/rear
Bilstien B16 coilovers with H&R anti roll bars
MRC stage 2 deflapped, precat gutted 439ps 481nm torque
1/4 mile time 12.884sec
My clutch replacement write up can be found here viewtopic.php?f=35&t=116929&start=15
Seattle-squash
Re: Clutch issue
Trust me you would kick yourself, if you did it all and left this out. Shortens travel/firmer feel. If you need help unless USP ships I can ship you one to simplify customs. And it would be a bitch to retrofit afterwards.
boombastik
Re: Clutch issue
Yeah gearbox basically needs to come out to replace these....I fitted a new one last year when I did the clutch if I knew about these I would have ordered and done it then.
boombastik
Re: Clutch issue
$83 shipping and still 6-10 days
Seattle-squash
Re: Clutch issue
Ok, good luck. I think it's doable with trans up but not a job you want to attempt.boombastik wrote:Yeah gearbox basically needs to come out to replace these....I fitted a new one last year when I did the clutch if I knew about these I would have ordered and done it then.
Seattle-squash
Re: Clutch issue
That's where I come in, I ship Europe pretty often to my family/friends. PM me if so and I help you out.boombastik wrote:$83 shipping and still 6-10 days
boombastik
Re: Clutch issue
Well $38 FedEx 2-3 days so purchased it with that shipping. Hopefully be in Aberdeen by next weekend €214 all in. About £145
Seattle-squash
Clutch issue
Boom! There you go, you will thank me later - yes please, I take a pint! Also a bit for you/mechanic we used some high temp Teflon to assure perfect fit for "life" to the slave given location and pressure tested several times prior to completing the assembly which limited access.
P.s good timing for you though, with them running a sale. I got mine at full price.
boombastik
Re: Clutch issue
Does the braided line run from the slave right up to the master replacing the steel lines as well as the rubber hose .?Seattle-squash wrote:Boom! There you go, you will thank me later - yes please, I take a pint! Also a bit for you/mechanic we used some high temp Teflon to assure perfect fit for "life" to the slave given location and pressure tested several times prior to completing the assembly which limited access.
Seattle-squash
Clutch issue
Yes sir, you will enjoy the cluster of the OEM lines which has several bends and splices, no wonder it feels so much better. You will see it...
boombastik
Re: Clutch issue
Obv a man talking from experienceSeattle-squash wrote:Yes sir, you will enjoy the cluster of the OEM lines which has several bends and splices, no wonder it feels so much better. You will see it...
Am I correct when I say you need to remove the master inside the car first to pull the clip retaining the pipe as looking down the side of the servo I can't see the pipe lol
Seattle-squash
Clutch issue
I was at my friends Shop for parts of the clutch install, but not for all. However, think all was done from outside/underside. And regarding "from experience"; yeah, pretty simple before and after comparisons. I do most of my own work but not this as I am not ready to pull a trans on my back with car on jack-stands.
boombastik
Re: Clutch issue
Yeah you need a lift to do the gearbox removal. That's for sure, I'm lucky that my cousin has a garage with all facilities I get to use.
Seattle-squash
Re: Clutch issue
Lucky guy! Also, sure you can find something online about it.boombastik wrote:Yeah you need a lift to do the gearbox removal. That's for sure, I'm lucky that my cousin has a garage with all facilities I get to use.
Also, If you read anything about the USP push rod is longer than OEM, which alters pedal location. That was an early version and has been fixed for years and now same length as OEM. I even called and talked to the USP team prior and confirmed update, followed my satisfied "testing". Anyways, just so you know. I am out for now, but good luck!
irn_bru_ce
Re: Clutch issue
So the original audi master cylinder is made of plastic? Outrageous
Users browsing this forum: Google Adsense [Bot] and 334 guests
