DRC front shocks rattle!
My 2015 fl lovely has developed an annoying rattle in the front right shock. Happens when going over minor undulations at slow speed mainly in comfort but sometimes I can hear it in auto and dynamic as well. Mind you the car has done only 12 000 kms. Took her to stealer and after a 2 hour inspection, drc pressure checks etc. they established that the other front shock rattles too. Apparently Audi are aware of the issue and are working on new front shock absorbers. I was told that the expected release date is around mid-June.
Re: DRC front shocks rattle!
I have this too and hoping to get Audi to look at during first service in a month or two. Did you dealer say they would rectify it once the fix was released? Keen to avoid "they all do that sir". Sounds like something is loose at low speeds and over potholes, drain covers etc.
Please keep us posted on progress with your car.
Mark
Mark
Finally the shocks came and I got all 4 replaced under warranty. They do feel a little tighter but some rattle is still present at lower speeds/sharper undulations. The original shocks had got better with time to the point that the rattle had all but gone. Weird...
Had mine done 2 weeks ago. All fixed
Mark & Gorun, which dealers did you have the work done at? Want to have some back up info when my local dealer inevitably tries to tell me there's nothing wrong with the shocks!
Current;
18 Daytona Grey RS4
16 Green R8
Past;
17 Misano RS6 PE
66 Sapphire BMW F80 M3.
18 Mythos Black RS4
14 Daytona Grey RS6
08 Monza Silver RS6 Avant
07 Phantom Black RS4 Avant
Loads of BM's inc. 4 x M's
18 Daytona Grey RS4
16 Green R8
Past;
17 Misano RS6 PE
18 Mythos Black RS4
14 Daytona Grey RS6
Current;
18 Daytona Grey RS4
16 Green R8
Past;
17 Misano RS6 PE
18 Mythos Black RS4
14 Daytona Grey RS6
18 Daytona Grey RS4
16 Green R8
Past;
17 Misano RS6 PE
18 Mythos Black RS4
14 Daytona Grey RS6
It is now a known problem with a fix and a bulletin for it that the stealers will know about
Zebede
911 C4s cab - summer is fun
Panamera Turbo - fully loaded - gone
RS6 C7 - Panther Black - dodgy steering
911 GT3 - awesome but ate tyres
RS4 b8 - Black on Black with Black windows
911 Targa 4s 991 - Black with Grey Leather
Known problem that the dealer will be able to look up the bulletin for, had mine done too
Zebede
Can any one actually believe that we are over 15odd years since the first DRC came out and Audi STILL can't get it right????
Beggars belief to be fair.
Every generation has issues!!!
Give it up Audi FFS.
RS6 C8 carbon black(merlin)
Panamera Turbo S e hybrid
RS6 C8 launch edition
R8 V10 plus
C7 RS6 PE dynamic pack plus
C7 RS6
Porsche Panamera Turbo
C6 RS6 AVANT
RS4 B7
Golf R32 mk 5
BMW M3 E46
Golf R32 mk 5
Golf GTI mk 5
VW Passat 130d 4 motion
VW bora 150pd
Ford Mondeo Ghia X V6
Ford Focus zetec
Rover 214!!
R8 V10 plus
C7 RS6
C6 RS6 AVANT
RS4 B7
Golf R32 mk 5
BMW M3 E46
Golf R32 mk 5
Golf GTI mk 5
VW bora 150pd
Ford Focus zetec
Rover 214!!
I think it's only coming from front on my pre facelift, but is the bulletin for all 4 shocks?
Current;
18 Daytona Grey RS4
16 Green R8
Past;
17 Misano RS6 PE
18 Mythos Black RS4
14 Daytona Grey RS6
18 Daytona Grey RS4
16 Green R8
Past;
17 Misano RS6 PE
18 Mythos Black RS4
14 Daytona Grey RS6
All 4 shocks get replaced
CheersMarkp wrote:All 4 shocks get replaced
Current;
18 Daytona Grey RS4
16 Green R8
Past;
17 Misano RS6 PE
18 Mythos Black RS4
14 Daytona Grey RS6
18 Daytona Grey RS4
16 Green R8
Past;
17 Misano RS6 PE
18 Mythos Black RS4
14 Daytona Grey RS6
Can someone expand in this bulletin ?
Is it a mandatory replacement if shocks?
Mine is at the dealers as there was fluid showing on the front shocks. They stated it was 'misting or sweating' which i know is bollox!
Not not mandatory. If yours rattles - typically at low speeds over uneven roads and from the front - then this is how Audi dealers are told to deal with it (after DRC check re pressure etc).
No rattle. No problem. It is normally evident from day 1 - or within a thousand miles at most. Presumably variable tolerances in some dampers. Not sure what they have changed but worked for my car.
Mine is in having all four shocks replaced under warranty as we speak. This may sound like a silly question, but I presume they will have to remove the wheels to do this? And will have to do a 4 wheel alignment after all work completed? Or will replacing the shocks not effect the alignment?
Current;
18 Daytona Grey RS4
16 Green R8
Past;
17 Misano RS6 PE
18 Mythos Black RS4
14 Daytona Grey RS6
18 Daytona Grey RS4
16 Green R8
Past;
17 Misano RS6 PE
18 Mythos Black RS4
14 Daytona Grey RS6
