Enabling TV whilst driving
Re: Enabling TV whilst driving
Pre or post facelift?
Pre mike sorry should have said 2013 car
Volvo XC90
C7 - RS6
C6 - RS6
B5 - RS4
C7 - RS6
C6 - RS6
B5 - RS4
Yes it's possible with VCDS. Do you have it or know anyone that does?
I have it mike could you possibly advise pls?
Volvo XC90
C7 - RS6
C6 - RS6
B5 - RS4
C7 - RS6
C6 - RS6
B5 - RS4
I've not tried this as it only works for pre facelift cars. In fact I think I did try it anyway but it didn't work.
Video In Motion - prevent the car from suppressing DVD playback once the speed of the car rises above 5mph
[Select]
[5F-Information Electr.]
[Advanced ID - 1A]
Make a note of the Serial Number
Go to Enable VIM TV-playback using VCDS/VAG-COM in your Audi MMI | trick77.com
https://trick77.com/enable-vim-tv-playb ... g-com-mmi/
Follow the link for MMI 3G
Enter your serial number into the input field
Make a note of the personal login code and the alternative login code it returns
[Security Access - 16]
Enter your personal login code.
[Do it!]
If you receive a "code not valid" message try the alternative code. If neither code works it's likely that your control module doesn't support VIM adaptation.
[Adaptation - 10]
Select channel 48
Press read
Set the value from 0 to 255
Press test
Press save
Press "Done, Go Back"
Close VCDS and reboot your MMI
To reboot the MMI (Press MENU, central MMI knob and top right softkey)
[Select]
[Advanced ID - 1A]
[Do it!]
[Adaptation - 10]
Select channel 48
Press read
Press test
Press save
That'll be £80 please
Haha no worries man - but jokes aside thanks!
Volvo XC90
C7 - RS6
C6 - RS6
B5 - RS4
C7 - RS6
C6 - RS6
B5 - RS4
- Silverfox42
Not tried this and off post, but would the same work for a '14 plate RS4?
Previous:
Previous:
May not work on a FL car but seems to be ok on pre FL cars
Volvo XC90
C7 - RS6
C6 - RS6
B5 - RS4
C7 - RS6
C6 - RS6
B5 - RS4
VAGNOSTICS
- Trader (Expired)
Works perfect on my 2014
Are you a Polish lorry driver ?rtd wrote:Has anyone managed to do this?
No are you?Covkiller wrote:Are you a Polish lorry driver ?rtd wrote:Has anyone managed to do this?
Volvo XC90
C7 - RS6
C6 - RS6
B5 - RS4
C7 - RS6
C6 - RS6
B5 - RS4
No just having a laugh, I was in a queue into Dover and a Polish lorry driver had a 20" laptop on watching a film whilst driving.
Users browsing this forum: Google [Bot], Mcw543 and 81 guests
