Exhaust
Re: Exhaust
looks like the ECS tuning H pipe is a bust. Just called up Awsome GTI they arnt coming back in till April 2017
looks like ill just fit it to the standard exhaust set up. If I need an OEM exhaust theres loads on ebay for 100 quid
Re: Exhaust
I had a B7 RS4 which I have now sold for a C6 RS6.
On my vehicle, I had gutted the rear silencers was lead to a much better sound than stock. Full throttle accelerations sounded great along with idle revving which had a delightful roar with crackles as the revs dropped. The beauty of this process was, I managed to keep the original stock tips and valves. Was very impressed with this inexpensive mod (at just £80) and personally, I think it sounds better than offerings from a number of leading exhaust manufacturers.
Dazz
Dazz
Re: Exhaust
Dazz,
Did this make the car stupid loud or was it just nice?? Any droning inside the car?
Re: Exhaust
You can use the Milltek non-res pipes and have them match up to the Tubi. As has been said before, its very loudBadman wrote:looks like the ECS tuning H pipe is a bust. Just called up Awsome GTI they arnt coming back in till April 2017looks like ill just fit it to the standard exhaust set up. If I need an OEM exhaust theres loads on ebay for 100 quid
Re: Exhaust
Yes but the Tubi has to be cut to mate up with the Milltek.Deano_123 wrote:You can use the Milltek non-res pipes and have them match up to the Tubi. As has been said before, its very loudBadman wrote:looks like the ECS tuning H pipe is a bust. Just called up Awsome GTI they arnt coming back in till April 2017looks like ill just fit it to the standard exhaust set up. If I need an OEM exhaust theres loads on ebay for 100 quid
Re: Exhaust
Hi Nicky,Nickygrs4 wrote:Dazz,
Non at all, for the £100 which it cost me. Was the best value mod I did on a vehicle.
Dazz
Re: Exhaust
Good point. Any half decent welder should be able to chop out the original resonator to give you straight pipesMikeFish wrote:Yes but the Tubi has to be cut to mate up with the Milltek.Deano_123 wrote:You can use the Milltek non-res pipes and have them match up to the Tubi. As has been said before, its very loudBadman wrote:looks like the ECS tuning H pipe is a bust. Just called up Awsome GTI they arnt coming back in till April 2017looks like ill just fit it to the standard exhaust set up. If I need an OEM exhaust theres loads on ebay for 100 quid
Users browsing this forum: Google [Bot] and 280 guests
