Losing washer fluid
Jules
Losing washer fluid
Post by Jules » Tue Nov 29, 2016 3:26 pm
Since last week I filled the washer bottle but its obviously dropping it.
I'm sure this happened with my old one too but the garage sorted when it was in for other works.
I removed the top cover and removed the actual bottle and no signs of a leak, so any thing common
with these ?
Where do you access through the wheel arch liner maybe ?
Drive low,park lower
jonytek
Re: Losing washer fluid
Post by jonytek » Tue Nov 29, 2016 4:52 pm
Have you had the bumper off recently? There's a plastic T piece that sits behind the bumper in front of the passenger wheel arch, last time I took my bumper off I broke the seal and it began to leak. There's a simple rubber o-ring that had cracked so a little bit of bush mechanics and a cable tie, good as new...
viewtopic.php?f=35&t=121438
BUILD THREAD
IG: @bad_rs_4
Covkiller
Post by Covkiller » Tue Nov 29, 2016 5:05 pm
I think it maybe a bumper off if it's one of the tubes to the motor. If you look at the bottom right of the photo below the two connectors you will see where the tube fits onto the pump:
Covkiller
Post by Covkiller » Tue Nov 29, 2016 5:07 pm
Better photo on jonyteks link
Jules
Post by Jules » Tue Nov 29, 2016 5:29 pm
Lovely thanks Gents, I need to remove bumper anyway to fit the new grill so good timing :thumbs:
Post by MikeFish » Tue Nov 29, 2016 5:34 pm
Isn't the bottle made up of 2 halves? I thought there was a potential to leak at the join.
PaulT
Post by PaulT » Tue Nov 29, 2016 5:51 pm
I had leak on mine when i bought it - dumping entire bottle contents in 4 or 5 screen washes.
The reservoir and pump are behind liner in passenger wheel arch - just remove liner to access. The pump and valve (directing fluid front and rear for Avant) seats into a seal in the bottom of the reservoir. For me the pump/valve was leaking when washer actuated and dumping a lot of fluid on the road was easy to see once exposed, the component is about £50 from Audi and replacing is all push fit. Worth checking the rubber seal the pump seats into, though this was OK on mine.
Daytona RS4
Jules
Post by Jules » Wed Nov 30, 2016 10:09 am
PaulT wrote:I had leak on mine when i bought it - dumping entire bottle contents in 4 or 5 screen washes.
Ah good point I forgot with being an avant it will feed both ways, taking the bumper off tonight or tomorrow so hopefully
things will become a little clearer then
Jules
Post by Jules » Wed Nov 30, 2016 10:11 am
MikeFish wrote:Isn't the bottle made up of 2 halves? I thought there was a potential to leak at the join.
I did check the bottle up top which was totally dry and I guess it would only lose the water to the point of a split.
Mines coming up on the dash out of fluid, so must be emptying it all
Post by MikeFish » Wed Nov 30, 2016 10:25 am
Ok then probably not the join as I think it would only half empty the bottle.
Users browsing this forum: No registered users and 393 guests
