Front window demisting issues (cold weather)
4.2 V8 32v FSI - 444 bhp
geoffdunk
Re: Front window demisting issues (cold weather)
Post by geoffdunk » Tue Nov 29, 2016 2:25 pm
OK, great, I literally press 2 buttons, if I dont need to do the rear its 1 button press and done. look forward to find out if we've helped, if not the Audi need to be involved.
MY2015 Audi RS4 Avant quattro, Panther Black Crystal, Black leather, Black inlays, 20" V-Spoke wheels
HPsauce
Post by HPsauce » Tue Nov 29, 2016 3:37 pm
In demist mode it will almost certainly turn off any recirculation and draw in outside air. So, yes, it may well get colder at first.
Post by Ian_C » Tue Nov 29, 2016 6:55 pm
Fuck - there was me thinking my DIY banger 1999 A4 was bad for this?!
I get into pretty much the same routine.... temp hi, fans high, hit the 'up' button to direct air at the windscreen vents (this was a front windscreen button on my B6 iirc) heated rear button on (which does side mirrors too as mentioned above)
And a trick I learnt 10+ years ago with my 205 GTI.... before you park up and leave the car, pop the drivers window down for the last 30 seconds of driving. Replaces warm moist air in cabin with cold air = less condensation overnight
At least being an old school 2.8 petrol it defrosts fairly fast!
HPsauce
Post by HPsauce » Tue Nov 29, 2016 7:00 pm
Ian_C wrote:At least being an old school 2.8 petrol it defrosts fairly fast!
4.2 S8 is never a problem, even when I've got scuttle drains full of water and the inside is dripping in condensation. :boohoo:
Post by Ian_C » Tue Nov 29, 2016 7:17 pm
Yes - when I commented to my best mate that my 4.2 S4 used to warm up quickly, he answered it was a bit like setting bank notes alight haha!
Very strange to see this B8 struggling?
Moonigan - maybe try temp high, fans high, heated rear, but *don't* press the front screen button tomorrow, see if the cabin warms up faster?
moonigan
Post by moonigan » Wed Nov 30, 2016 8:52 am
Sadly nothing to report as for some bizarre reason my car was untouched by the overnight frost despite being parked in the same place.
Post by Ian_C » Wed Nov 30, 2016 9:10 am
Ian_C wrote:I get into pretty much the same routine.... temp hi, fans high, hit the 'up' button to direct air at the windscreen vents (this was a front windscreen button on my B6 iirc) heated rear button on (which does side mirrors too as mentioned above)
Moonigan - this morning I started my car for a few minutes before I left for work, buttons/fans set as described above, and when I got in to drive it to work, I didn't touch a single button and drove to work.
I can confirm (on my old school B5 at least) if you have the fans directed to the windscreen, with the temp on max, the car 100% blows hot air (hotter as the engine warms up etc)
geoffdunk
Post by geoffdunk » Wed Nov 30, 2016 9:52 am
There is no need to go to this extreme, cars with AC or CC, get in, start up, press one button, screen demist, that's it. Modern systems are cleverer. If you have no AC then its different, you need a bit of warmth to dry the air, in that instance cracking a window also helps expel moist air thus drying out the cabin environment quicker.
If the one button method doesn't work on a B8 then Audi need to be involved, I have a video of mine de-icing and de-misting in under 8 mins from absolutely cold startup with a frozen screen.
Post by Ian_C » Wed Nov 30, 2016 11:06 am
(I should add, I only let mine run for the last two mornings because it was frozen solid!)
moonigan
Post by moonigan » Sun Dec 04, 2016 11:12 am
First frost for a few days this morning so I tried the one button technique and within 10 mins the screen and side windows were clear. Thanks for all the help!! :bowdown: :thumb:
Post by Ian_C » Sun Dec 04, 2016 2:42 pm
Auto button? Or front windscreen demist button?
moonigan
Post by moonigan » Sun Dec 04, 2016 3:06 pm
Ian_C wrote:Auto button? Or front windscreen demist button?
Sorry, front demist button.
geoffdunk
Post by geoffdunk » Sun Dec 04, 2016 4:36 pm
moonigan wrote:First frost for a few days this morning so I tried the one button technique and within 10 mins the screen and side windows were clear. Thanks for all the help!! :bowdown: :thumb:
Clad to here it worked, as I said its all I ever do.
Modern cars have a lot of effort put into the design of them, both function and aesthetical to make these systems work as they should and look good.
