Car feels like it's taking off goes all wobbly ??
Eddie555
Re: Car feels like it's taking off goes all wobbly ??
Post by Eddie555 » Fri Nov 25, 2016 1:27 pm
chunky79 wrote:That's a fail safe, got under crackers on.
I'll correct you there my friend. That is a fart filter.
Current ride’s
Previous rides
Post by chunky79 » Fri Nov 25, 2016 5:47 pm
Not much filter there!
Eddie555
Post by Eddie555 » Fri Nov 25, 2016 7:49 pm
chunky79 wrote:Not much filter there!
It only needs to cover the poo exit
Current ride’s
Previous rides
Post by chunky79 » Sat Nov 26, 2016 2:26 am
It'll be like cheese wire.
Eddie555
Post by Eddie555 » Sat Nov 26, 2016 7:51 am
Perfect! I'll have mine on Jacobs crackers please.
Current ride’s
Previous rides
Leo-RS
Post by Leo-RS » Sat Nov 26, 2016 4:11 pm
D3855 wrote:Update:
Tyres all have 40psi in them. My sticker was rippped hence didn't see the 21 bit.....Had alignment done at kwikfit, And it's still the same :( it was tuned today and while it was on dyno you could see the drivers front wheel shaking! Badly buckled! So now have just book tht in to have straightened out. Then once that's done if the torque steer is still there then it's time to try find a alignment specialist.
Do u think that the buckle could be causing my torque steer? Like when flooring it the wheel is wobbleing that much it's not keeping flat on the ground! ?
Did a search and seen loads of guys having problems with the buckled wheels on these. Wonder if the hole torque steer problems are all down to buckled wheels!
I have had my car tuned, I've also had the alignment done by a specialist.
There is still crazy amounts of torque steer at the moment, i haven't had proper 1st/2nd gear grip since early October. Back end is wild just now and car will happily go sideways if it's not corrected.
You'll probably be chasing your tail, you can't defy the laws of physics ;)
MY16 Audi RS6
Post by MikeFish » Sat Nov 26, 2016 6:59 pm
Leo-RS wrote:
D3855 wrote:Update:
Mine doesn't torque steer Leo.
Leo-RS
Post by Leo-RS » Sat Nov 26, 2016 7:31 pm
Damp cold roads and 1000nm of torque to blame for that Mike, it was a lot more manageable when it was warm and dry so I presume my alignment is good and all down to the current cold conditions. Launching from the brakes is just a major No-No :lol:
MY16 Audi RS6
Markp
Post by Markp » Sat Nov 26, 2016 7:32 pm
Nor mine - now - but only running standard power.
Post by MikeFish » Sat Nov 26, 2016 8:00 pm
Yes standard power and good traction conditions for me too. I know you are running more power Leo. I thought you said it did it as standard too but I may have misread.
D3855
Post by D3855 » Sat Nov 26, 2016 8:42 pm
Markp wrote:Nor mine - now - but only running standard power.
When u say yours doesn't now. Did it before u had alignment done or was it summit else u had done that fixed the torque steer? If it was the alignment you don't no what they set it at do u?
Post by MikeFish » Sat Nov 26, 2016 8:44 pm
Did you not look at the 3rd link in the first reply you had to this topic?
D3855
Post by D3855 » Sat Nov 26, 2016 9:31 pm
Yes mate I had even screen shot your alignment witch will show him tomz and also read Ian's info about putting rear toe in at 0. But your rear toe isn't 0? It's 0.12? Or is anything in the 0 zone ok? Sorry just trying to get as much info as poss before goes in tomz
D3855
Post by D3855 » Sat Nov 26, 2016 9:37 pm
Mike of yours doesn't torque steer I will just get them to set it at what yours is set at init lol
Post by MikeFish » Sat Nov 26, 2016 9:47 pm
I just told them to get it as close to OEM settings as they could.
Users browsing this forum: Google Adsense [Bot] and 152 guests
